Ripped seat TSB
Yeah that's probably the sensible thing to do. But life is full of non-sense. The thing that I would have to figure out is the TSB indication that the left side seat cushion trim has to be replaced. Correct part number requires the VIN and the electronic parts catalog (FAST or equivalent). I don't have any access to that level of variable part number detail research. I'd also have to source two probably obscure clips for the seat cushion outer finisher.
Might have to let the dealer do it at a premium.
I have the rip as well for a few years and its been getting worse. I tried looking to replace it with OEM parts (foam/seat cover) but the price is absolutely outrageous. Foam cushion itself is over 575, and just for leather trim lower seat is 1,900. I tried Katzkin, but of course they dont make anything for our cars. Seems like only way to go is through a random upholstery shop and they want anywhere from 500 to 700 per seat and do not guarantee that the leather will match up to the oem color. frustrating
Thought I should report in on this. I finally just let the dealer deal with it. The seat bottom is no longer available, but since it wasn't yet torn, I was OK with that and not having to buy a new one
They performed the filing modification and put it all back together. We shall see how it does over time. Still kind of shocked that no one apparently ever DIY'd this....
![Icon38](https://g35driver.com/forums/images/smilies/icon38.gif)
Received 1,486 Likes
on
Labor @ $135, plus two pins (01553-01034) @ $23.14 each, total $181.28.
Interestingly, a parts lookup at infinitipartsdeal.com says the pins at that part number (for $8.90) do not fit my vehicle, provides a lookup code of 87300EF that leads me to 87300E (part #87648-AC70A) that looks like a clip, requires two @$2.01. Whatever. Like I said above, at a premium.
Last edited by G2B35AGN; 11-06-2017 at 09:17 PM. Reason: Add pin part #; add parts research
Upholstery shops in my neighborhood are major flakes, I won't even go into detail but I couldn't do business with any of them...they're that bad! www.leatherseats.com wants K$ for just the leather for both front seats, then I need to find a reliable individual to do the install. May have to rely on Nissan's mobil unit to get my drivers seat repaired, dislike leaving SLICK anywhere is part of my OCD! ![Eek3](https://g35driver.com/forums/images/smilies/eek3.gif)
Gary
Gary
I redid my seats and wrapped my dash in vinyl leather. Also if any of you guys are looking, I found this website called yourautotrim.com and they sell all types of vinyls and leather. They have headliner too and a bunch of other stuff, yall should look at it, its helped me a lot.
If you dont want to post it here, please PM me. trying to figure out how much i it should be.
Also, would it be wise to order replacement parts from infiniti or do they not make them anymore?
Found the solution to my torn/worn drivers seat, talked to the service manager at my dealership and he recommended this small company. First visit didn't go well, it was 10:00 and he wasn't go to be at his shop till around noon.
Went back a few weeks later and he was working on a project but he gave me a quote along with a ride home while they worked on SLICK. Three hours later he called and she was ready, they replaced all the leather on the left side of my drivers seat and fixed the lower piece that causes the damage in all our coupes. This isn't a DIY project, what are going to do tape leather over the hole...tried that! ![Icon17](https://g35driver.com/forums/images/smilies/icon17.gif)
Gary
![Icon43](https://g35driver.com/forums/images/smilies/icon43.gif)
Gary
#30
