Remove the Central Tray from Rear Seat
Old Apr 3, 2006 | 12:58 AM
ansetou's Avatar
Does anyone know how to remove the entire central tray from the rear seat? I'm talking about the plastic part that includes the cup holders located in the middle of the rear seats of a coupe. I want to remove the whole thing, not just the lid or the cup holders. Any ideas? The service manual is useless on this. Thanks.
Old Apr 3, 2006 | 12:59 AM
mc2's Avatar
mc2
i wonder if the seats ahve to come out
Old Apr 4, 2006 | 12:06 PM
ForceFedG's Avatar
All you have to do is put your hand between the seat and the plastic piece,grab the plastic piece and pull slightly up and and towards the front of the car it should slide right out....to replace the piece, just replace the plastic clips and slide back in....let me know if this helps...
Old Apr 4, 2006 | 01:23 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Be very.....very....very....careful when pulling this part out i pulled too hard and broke the two clips that hold it in place, mabe im just an idiot but the two clips are very easy to break.
Old Apr 4, 2006 | 01:28 PM
Bleser's Avatar
What is exposed once you remove this section? Bare metal?
Old Apr 4, 2006 | 01:59 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Theres some kind of a heat sheald(Basicaly the foam pad you see under carpets) and under that is bare metal...
Old Apr 5, 2006 | 12:59 AM
Disco_Monkey's Avatar
To avoid breaking any clips. Just remove the whole rear seat then remove the plastic.
If you take that off, it's going to be ugly and broken looking.
Old Apr 5, 2006 | 02:25 PM
ansetou's Avatar
Got it! Thank you all for the precise information. Actually sliding it forward was not easy. I still kinda lifted it. And it needed such a force that I was worried about breaking it.
Now, what would you suggest to cover it? It's not such a good image underneath that thing. I removed it because I sometimes attach a infant carseat to the middle of the rear seat and I determined the middle is the best position. But when I don't have a infant seat, I would like to cover that big hole.
Any suggestions?
Old Apr 5, 2006 | 07:32 PM
TURBOTOM's Avatar
a.k.a kleicoupe
Look up rugratcoupe he is a member here and he had a custom piece made to fill the gap....hope that helps.
Old Apr 6, 2006 | 04:47 PM
ansetou's Avatar
Thanks. I found this thread which seems to be talking about it. And he listed "Interchangable Pad or Rear Seat Console."
https://g35driver.com/forums/interior-exterior/52408-q45-lens-mod.html
but the pics are not clear there. so I pm him.
tiguy99
Mar 1, 2016 11:42 AM
Th611
Oct 27, 2015 03:48 PM
wuppiedog
Aug 7, 2015 11:16 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
Xanthan Gum
Aug 6, 2015 10:49 AM
