2003-2006 Lamp Replacement Guide
Old Sep 19, 2006 | 02:14 PM
mephistomyhero's Avatar
Originally Posted by aHero4Eternity
why didnt you just go to sylvania.com and use the actual lamp replacement guide?
Well, they did list the 2006 lowbeam as a D2R
Also, what's the difference between 168/194? I have a 2006 coupe housing and I want to buy the bulbs for them. I know the lowbeams are D2S, High/Fogs are H1, but I'm not sure on the parking lights. I know the 2005 doesn't have them, so any help here? Thanks.
Old Sep 19, 2006 | 02:47 PM
Calvin's Avatar
Overglorified Altima
low/high beams are d2s bro. you have bi-xenon lights! h1 is your fog light
168 and 194 bulbs are the same. you can interchange them anywhere
Old Sep 19, 2006 | 02:57 PM
MixturePinoy's Avatar
I was looking for this guide, thanks.
Old Sep 19, 2006 | 04:42 PM
nchaurdia's Avatar
this is great! it would be even better if we had a follow up thread on how to change each one of those lights and then sticky both!
Old Sep 21, 2006 | 11:44 PM
j.le's Avatar
anyone know the size for step and map lights there 3022
is it 31mm?
Old Mar 13, 2011 | 07:59 AM
VincenzG35's Avatar
What are the clock bulbs?
Old Oct 6, 2012 | 09:24 PM
saltyload's Avatar
For the 2006 coupe fog lights using an H1 bulb, does it matter if it is 35Watt or 55Watt? Will the 55watt burn anything? Planning on buying a ddm kit. Thanks.
Karl_g335x
Aug 3, 2015 03:43 PM
keithk831
Steering & Suspension
Aug 2, 2015 09:50 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
ClwMike
Jul 23, 2015 12:55 PM
Thunderaan
Jul 22, 2015 07:40 PM
