How do you remove the front turn signal bulb?
Do i turn it? pull it? release some tabs?
Here is a pic of it from the inside.
http://www.anythingbox.net
Re: How do you remove the front turn signal bulb?
Not sure how to help you without seeing it for myself, but what's up with your wiring dude? Have a little fire?
G
2003.5 Black w/ Willow G35
Premium / Sport / Aero / Winter / Navi / Tint
G
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Which bulb are you talking about? The round orange reflector one or the one for the long stripe? In either case, you just twist the bulb holder about 1/4 circle, and it should come out.
I would get those wires fixed. That looks dangerous.
The turn signal bulb. Round orange reflector.
I just grab that holder with those 8 wires leading from it and turn? Have you done it? I tried on mine and thought that thing was going to break.
As for the wiring, I had a mouse living in my fender protector
Actually, i'm trying to tap into the turn signal to blink the side marker. Having the hardest time.
Actually, the thing with the 8 wires (the rectangular black thing) is the main wiring for the entire headlight. You have to somehow reach beyond that thing to get to the orange signal bulb. It should be a smaller, circular connector.
DAMN! You got to be sh!tting me!! I've been tapping into the wrong wires? So its deeper into the fender well, behind the rectangular black thing? Is it just a pos/ground wire leading into that bulb?
If you want to get to the bulb, you'll have to reach farther medially (towards the midline of the car). If you just want to tap into the wires, you can try the wires around the rectangular box.
If you want to pull out the rectangular box, pull towards the rear of the car. It should slide out.
MyfistYourFace
Aug 8, 2015 11:58 AM
Nick_M
Aug 3, 2015 11:08 PM
