Adjusting Headlight level
Old Nov 11, 2006 | 12:57 AM
codeflux's Avatar
Originally Posted by Triji
I am doing a DIY on headlight removal tomorrow and I will post pics in that write up of where the height adjustment screw/bolt is as well.
there is already a DYI on that - look in the DYI section. i know i've seen it.
Old Nov 11, 2006 | 01:08 AM
Triji's Avatar
I did not see it in there... I just looked again for it actually...
Old Nov 11, 2006 | 01:42 AM
codeflux's Avatar
weird i swear i've seen it..
well write another one!
Old Nov 21, 2006 | 01:10 PM
chobble19's Avatar
still havnt f'd with mine wheres the DIY?
Old Nov 21, 2006 | 02:04 PM
codeflux's Avatar
oh jeez you lazy phuckerz!
open you hood, stand next to the fender, and look on top of your headlight housing. you will see a small 1/2" hole in the housing, with what looks white plastic gears. that's the up-down adjustment. you will need a 1/4" flat screwdriver to rotate it from the top - it's very difficult to get to it from the rear. park your car in front of the wall, and go at it! be careful not to break the gears - go slow.
Old Nov 21, 2006 | 09:43 PM
.moO^.'s Avatar
which way to raise the aiming? clockwise?
Old Nov 22, 2006 | 12:33 AM
codeflux's Avatar
i forgot. try it both ways, you can see pretty well which way it's going, especially if you're a few yards away from the wall.
Old Nov 22, 2006 | 01:52 AM
razo168's Avatar
new aiming question.. if this is how to aim your headlights. how can you aim the fog lights?.. i got HID fogs.. and they are bright!.. aimed really high on one side.. i dont even want them to turn on yet.. but yea.. HELP ! =(
Old Nov 22, 2006 | 02:23 AM
codeflux's Avatar
there should be an adjustment screw for the fogs also, but you're gonna have to sniff all around your headlights to find it... good luck! /me grumbles about people putting HID fogs in their cars, losing high-beams, and blinding other drivers...
Old Nov 22, 2006 | 02:10 PM
razo168's Avatar
hehe .. i acutally got bixenon hid fogs.. that have high beam.s. but yea.. they blind.. i ha ve them off for now.. they are really high.. so i have ot aim them down.. anyone have a picture of where it is and such?
Old Nov 23, 2021 | 07:32 PM
Stacey221987's Avatar
Infiniti g35 coupe
To adjust the headlights
Originally Posted by delion21
Does anyone know how to adjust the 05 Coupe headlight level? there is some wierd screw hole wwith w gear inside but I cant get it turned....any ideas?
There are two holes when u open the hood. You need a Ling Phillips screw driver you sick it angled into the hole the one is for the low beam the other for the high beam. There is a round plastic guide inside each hole slide the screw driver right into it and u will head the little gears. The Phillips tip grooves turn the gears for u its super easy!!
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
ENTRAPM3NT
Sep 16, 2015 01:21 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
