Headlights + Fogs + Clears Installed
Old Dec 31, 2006 | 02:58 AM
TwixG35's Avatar
Ok so i installed:
Philips 5000k D2S Projector Bulbs
PIAA Xtreme White Plus 4000k H1 - Fogs
PIAA High Intensity LEDs 168W - Clears
They were originally kinda F'd up....but i spent a little time tweakin' em around etc...and finally got them to work!
Image 1: All Messed Up
Image 2: Fixed
Image 3: Projectors - Low-Beam
Image 4: Projectors - High-Beam
Image 5: Projectors, Fogs, and Clears all On
Attached Thumbnails Headlights + Fogs + Clears Installed-dsc00450.jpg   Headlights + Fogs + Clears Installed-projectionground.jpg   Headlights + Fogs + Clears Installed-lowbeam.jpg   Headlights + Fogs + Clears Installed-highbeam.jpg   Headlights + Fogs + Clears Installed-everything.jpg
Old Dec 31, 2006 | 03:01 AM
Slyding_G35_03's Avatar
OHH MAN.. do u have 2 register on the other site? s der any way that u can clip it to the forum?
thanx.
Old Dec 31, 2006 | 03:14 AM
TwixG35's Avatar
thanx.
Fixed
Old Dec 31, 2006 | 03:25 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
Why was it messed up in the first pic? The bulb not seated correctly?
Your beam seems to be aimed a bit low, you should be able to see farther than that.
Try to post some pics of the beam pattern against a wall from more than a few feet away. It's hard to tell beam patterns when the car's right against the wall.
Old Dec 31, 2006 | 03:36 AM
TwixG35's Avatar
done!
Image 1- Lows
Image 2- Highs
Attached Thumbnails Headlights + Fogs + Clears Installed-dsc00464.jpg   Headlights + Fogs + Clears Installed-dsc00466.jpg
Old Dec 31, 2006 | 09:04 PM
IvoryGT's Avatar
this is on a 06? I didnt know that the cutoff was THAT bad.
Old Dec 31, 2006 | 10:32 PM
chester's Avatar
something doesn't look right!
Old Jan 1, 2007 | 04:19 PM
Triple8Sol's Avatar
Good choice on the 5K hids. It does look like you should adjust the beam (raise it a bit) and even them up while you're at it...
Old Jan 2, 2007 | 02:39 AM
TwixG35's Avatar
How do i go about adjusting them to be higher?
Do i just go back into the fender wall / back of the headlight to adjust them?
Old Jan 2, 2007 | 10:26 AM
Bigd2k6's Avatar
put bags of sand in your trunk... lots of them.
Old Jan 2, 2007 | 12:25 PM
Calvin's Avatar
Overglorified Altima
for my 06 projectors there are 2 8mm nuts behind each headlights...turn them to adjust
Old Jan 2, 2007 | 01:02 PM
IvoryGT's Avatar
definitely adjust the lights more to the right of the road, from your picture it seems to cover most left side.
Old Jan 17, 2007 | 06:37 PM
marty315's Avatar
What are your thoughts on the PIAA extreme force??
Old Jan 17, 2007 | 06:43 PM
Calvin's Avatar
there is an 8mm bolt behind the lights (one for fog, one for hid). turn it to adjust.
or was it 10mm
no i think it was 8mm...
Jusseth
Sep 13, 2020 12:25 PM
Freddy07g35
Sep 17, 2015 08:53 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
Tylerttn
Jul 14, 2015 10:11 PM
