LED Parking/Blinker Clear Corner Teaser
Old Jan 9, 2008 | 02:03 PM
redlude97's Avatar
Originally Posted by ShanesG
can you buy leds like this with the correct size to fit in your side marker, that you dont have to solder and you can just wire it up
no, this required dremelling apart the sidemarkers
Old Jan 9, 2008 | 02:14 PM
MidnightG35X's Avatar
+1
This was a custom mod, not just a drop in bulb solution.
Old Jan 9, 2008 | 02:33 PM
ShanesG's Avatar
no no, thats not what i meant, i mean t do they have strips that dont require soldering , i know id have to modify the back part, i was asking id they have some that are the size that will fit that i can just wire in and not have to solder
Old Jan 9, 2008 | 02:39 PM
redlude97's Avatar
Probably not, if there was, I doubt MidnightG35X would have gone through the trouble of custom making his own
Old Jan 9, 2008 | 02:54 PM
https://g35driver.com/forums/showthr...ighlight=cheap
There is an example of someone who used a premade strip for cheap. I did not go that route for a few reasons.
1. I wanted complete control over the parts used (I have no idea which exact LED's are in those strips)
2. I did not want them exactly like that. I wanted more LED's and a blinker function also.
3. I like doing my own projects like this
So if you are looking for premade strips, that above post should help ya out. Good luck!
Old Jan 9, 2008 | 02:57 PM
O HELLA JDM's Avatar
das pretty damn bright haha
Old Jan 9, 2008 | 03:42 PM
ttrank's Avatar
Grocery getter
The only easy way is to install some very bright 194 LED's in there. I had that before and it was nice and bright but nothing like this!
Old May 16, 2008 | 05:54 PM
Bigd2k6's Avatar
where exactly did you split the lens assembly at? very nice work by the way.
Old May 17, 2008 | 02:14 PM
Thanks. I split the lens assembly at the "pointed" corner. All I did was take a dremel, make a very small cut between the lens and the backing until you could see inside the lens, then gentle prying with a screwdriver got the rest off. The glue holding it together is not super strong, so prying with the screwdriver worked great.
Old May 18, 2008 | 10:10 AM
Bigd2k6's Avatar
man, i'm seriously considering this mod (yours, not the cheap premade strips from superbright) but I don't have access to all the soldering tools since i've changed jobs. have you had any problems like fogging in the lens or the infamous flickering of cheap quality LED's. i haven't pulled up the link to the place you bought them at but they look to be high quality. Those are SMT's, correct?
Old May 19, 2008 | 11:17 AM
I have not had any problem with lens fogging. No LED flickering problems either. Using a high quality LED and not overdriving them will make your LED last a long time. For this project, the key to not overdriving the LED's is using a proper size resistor. My LED's are not SMT, they are in a 4-DIP package. This makes it a lot easier to use a breadboard that can be had at any radio shack or electronics supplier. A PCB is unnecessary for this simple of a project, although it can be made (I think I made one after the fact for some reason). I am not a huge fan of higher power SMT's.... I really don't want to do thermal planning to deal with the small area/high heat issue. Here is a picture of the package:
Old Feb 28, 2009 | 05:40 PM
ddep's Avatar
Hi Midnight, how did you manage to take the corner light apart, from your photo looks like you didn't had to force it. I tried to bake it and but the glue is not budging. I tried the hate at 200, 250, and finally at 300 and the light start to deform.
Thanks,
Old Mar 1, 2009 | 02:55 AM
psedog's Avatar
Back in SD**
Midnight, I have the Yellows and red-orange led's like yours (HP/Agilent Lumileds HPWT-DH00 and DL00). Do you know of any good Blue leds that are this style? I'd like to put blue and yellow into my corners. Reds are going in my tails.
Old Mar 2, 2009 | 10:58 AM
Thanks,
I took a dremel to the corner (pointy corner... one on the top side closest to the doors) just enough to cut through (maybe a 1" cut). Once you get that initial cut, just throw it in the oven for 3 minutes at 250. Take it out, use a flathead screwdriver in the cut you made and pry up. Should come apart very easy. The glue is not that strong on the clear corners, nothing compared to the taillight stuff that requires you to dremel the entire thing
Make sure you fill the dremel hole with epoxy or silicone after you put the lights back together.
Any brand name LED would probably be fine (Lite-On, Lumileds, Cree, Osram, Nichia). Below is are some links to a couple... all depends on what you want.
http://search.digikey.com/scripts/Dk...me=160-1639-ND
http://search.digikey.com/scripts/Dk...FS-CF0H0454-ND
You will most likely have to change your resistor values also due to blue LED's having higher voltage. Blue will always appear less bright than red or amber due to being less efficient. Also, you have to deal with legalities of using blue in any of your lights
Old Mar 2, 2009 | 01:17 PM
  #30
blk06x's Avatar
I see you have an X which means you do not get to wire into a clearance strip like the coupe guys can.
I would be interested in knowing what wires you tapped into to flash the blinkers.
I have most of my parts just was curious how you have the blinking row working
