LED under glove box/steering wheel help
Old Mar 6, 2007 | 09:32 AM
yizhao's Avatar
Originally Posted by dcityjatt
i beeen meaning to do thiss!!!
i even bought the lights from pep boys (have had em for more than 2 months)
ne way possible if you can provide a link to this product on pepboys website?? just want to make sure i have the correct one...i think it has like 15 led's spread apart by maybe an 1 inch each?
oh i cant wait now!!
i couldn't find the link on Pepboys.com but what you have described sounds exactly right. i'll put up a DIY when i get a chance.
Old Mar 6, 2007 | 09:46 AM
dream_G35's Avatar
Originally Posted by Deftronix
You will definitely want to tap into the map light circuit.
I actually did something similar with 4 12" white ccfl tubes.
You can get to these wires right at the BCM (in front of driver side door)
Heres a picture with the info u need (this is the connector furthest right):
Pin 1: Red/Black (+12v)
Pin 8: Purple/Red (-)
1)Im a newb at electric work, wut do u mean by tapping in(splicing wires)? picture?
2) where can i find those ccfl tubes/will they get hot under rear passengers legs?
Old Mar 6, 2007 | 10:22 AM
yizhao's Avatar
tapping just means touching the wire you want power to, to the +,- wires that has power already. all you have to do is strip the insulation off the wires of the light source and stick it into the +,- and use electric (black) tape to hold it in place (make sure the + and - doesn't accidentally touch).
Old Mar 6, 2007 | 02:07 PM
Steel Blue's Avatar
Is the above pic in the cabin or in the engine compartment?
Old Mar 6, 2007 | 07:15 PM
yizhao's Avatar
that was confusing to me at first too but when i looked around, its a lid to the left of the pedals that comes off. the dead pedal (i think thats what its called) is kind of in the way but no biggie.
Old Mar 6, 2007 | 08:34 PM
DHCrocks's Avatar
Originally Posted by aleok
I did mine also, DHCrocks helped me.
That came out great. looks good. did you do the trunk too?
Old Mar 6, 2007 | 08:40 PM
dcityjatt's Avatar
the above picture, is it like a wire harness that is plugged in there? can i pull it out? or do i have to pull out each (#1, #8) of them individually?
please provide a detailed diy, if possible? would really appreciate it!!
Old Mar 6, 2007 | 08:47 PM
DHCrocks's Avatar
it's a plug you can pull out the whole harness at one time. You can't really pull out the individual wires you need a special pin removing tool for that.
Old Mar 6, 2007 | 09:41 PM
Deftronix's Avatar
For those of you who wanted more details:
BCM Harness furthest right (near driver side foot plate. See picures below)
Use these pinouts to connect inverters/leds
Driver side:
Drill a hole a couple inches in front of the ridge in the back of the trim piece.
Now you can run a zip tie around the ccfl, through the hole and attach it.
The inverter you see in this picture was pushed in after install was completed
Passenger side:
Take out the lowerdash piece to allow enough access for installation. Use zip ties to secure.
Picure with oem trim piece reinstalled:
Rear:
Use an exacto knife or anything sharp to put 4 holes for each tube in the carpet. Thread zip ties through these holes and attach ccfl's.
I put the inverter for these tubes in the first aid compartment. (yes the first aid kit still fits)
Hope this helps! Have fun!
Old Mar 7, 2007 | 03:14 AM
wuchen1's Avatar
nicee where did u get the tubr from?
Old Mar 7, 2007 | 05:07 AM
aleok's Avatar
yea, i did the trunk too, but i regret doing it in blue, looks to ricey, i'm kinda embarrased when opening my trunk, should have gone with white..
Old Mar 8, 2007 | 05:20 PM
G35000's Avatar
how did u change ur door light? it does not pop out as easly as the domelights
Old Mar 8, 2007 | 08:43 PM
aleok's Avatar
^ it does pop out, but yea, not as easy as the dome. just ply it.
Old Jun 23, 2007 | 12:23 AM
FlSHRFun's Avatar
Question
Driver side:
Passenger side:
Rear:
Hey, Deftronix. Could you provide a bit more detailed installation of the rear seat lighting. I've done lights for under my steering wheel and glove box, but which wires did you tap into for the rear seat lighting? Did you tap into the same wires? If so, was it difficult to run the wires discretely from the front to the back?
Old Jul 7, 2007 | 12:39 AM
  #30
Deftronix's Avatar
Yes, the same wires were used to hook up the ccfls in the rear. I ran the power under the door molding, it is not visible.
