A couple HID questions...
Old Mar 12, 2007 | 01:03 PM
salty1's Avatar
I understand our factory HID's are 4300K. (I think) I am thinking about installing the PIAA Super Cobalt 6600K D2R HID from Everything g35.com and wondering...Is the temp on 6600k noticeably bluer? I am looking for that blue look comparable to the factory Acura TL.
Also, I read that the D2R and D2S are compatible with the newer-ish D2C bulb assembly. Is that really true?
Old Mar 12, 2007 | 01:12 PM
5150DS's Avatar
I would think 6600 is almost purple.
Old Mar 12, 2007 | 01:26 PM
NonAme's Avatar
6600 has a tint of purple
i replaced my foglights with 5000 and it matches the stock HID perfect and thats the best lighting visibility.
Old Mar 12, 2007 | 01:56 PM
ttrank's Avatar
Grocery getter
The Piaa 6600 bulbs are a lot more blue/purple than the stock 4300k bulbs.
You will loose some output with those bulbs. Anything over ~4300-5000k begins to drop in actual lumens output.
What you are seeing with the TL/S2k,TSX, etc, is the cutoff of the projector. To get that type of effect you have to do a projector retrofit which is so worth it just for the additional light output and reduction of glare on other drivers.
Old Mar 12, 2007 | 02:17 PM
Calvin's Avatar
Overglorified Altima
yep, ive seen the piaa 6600k and theyre super purple (imo)!
Old Mar 12, 2007 | 04:53 PM
redlude97's Avatar
Exactly, color at the cutoff is what you want, not a purple color throughout. Its easy to spot a real projector flicker, and high kelvin bulbs because they don't change as drastically.
KallDay86
Jan 8, 2016 12:42 AM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
Visionnn
Oct 3, 2015 05:16 AM
hrdwirk1
Oct 2, 2015 06:34 PM
