HID Question
Old Mar 19, 2007 | 12:48 AM
.moO^.'s Avatar
HID Question
I'm interested to know if I get an aftermarket HID for my fog (H4), can I also get same bulb to replace to the OEM HID low beam while using OEM ballast? Essentially I have the same color....
Old Mar 19, 2007 | 12:59 AM
redlude97's Avatar
You want to reword that one? Are you trying to run 2 HID bulbs off of 1 ballast? If so that won't work. If you are trying to run it off of 2 OEM ballasts, yes this will work, but you will have to cut off the ignitor plug and rewire it, because you'll have to used rebased h4 d2r bulbs, which usually come with wires instead of being able to plug the ignitor directly into it
Old Mar 19, 2007 | 02:02 AM
caskyline's Avatar
Former Vendor
Hey, I can now get the HID upgrade kits for you,Also if you want to udgrade the D2R bulbs.Give me a call or PM.
Old Mar 19, 2007 | 11:35 AM
.moO^.'s Avatar
Sorry, let me see if I can re-word to make more sense.
Basically my goal is to have my fog and low beam to have the same matching color. In order to do so, I was planing on getting an aftermarket HID kit (bulb, ballast, and ignitor) for my fog light. While keeping my OEM low beam ballast, can I get the same bulb as the fog light HID kit and run it off my OEM low beam ballast? At the end I have the same matching color except I don't need to purchase two kits.
Old Mar 19, 2007 | 01:09 PM
IvoryGT's Avatar
Just get bulbs of the same color temperature from the same company.
You will need a H4 kit and a d2r bulb. assuming you don't have a 06. Because 06 runs H1 and D2S
Old Mar 19, 2007 | 02:26 PM
.moO^.'s Avatar
Yep! H4 Kit and D2R bulb is what I'm planing on doing. (03')
Where can I find the best price for Phillip kits?
Thanks for the help!
Old Mar 19, 2007 | 04:23 PM
IvoryGT's Avatar
Philips don't make kits last I know. You might be able to find H4 rebased bulbs and use regular ballasts. But you need to find the actuated ones, so your high beam still works.
Old Mar 19, 2007 | 05:36 PM
.moO^.'s Avatar
Doesn't Phillips make some builb and ballast? but aftermkarket company carry them?
Anyway... do you happen to know where I can find some good price HID kit?
Old Mar 19, 2007 | 06:59 PM
redlude97's Avatar
Most aftermarket kits don't use philips bulbs and ballasts but rather generic made in asia bulbs of unknown quality and generic ballasts
Old Mar 19, 2007 | 07:05 PM
DHCrocks's Avatar
you can just get a 4100k H4 for the fog and it'll match the stock headlight. That's what I did. I would recommend you go for the bi-mode (or what ever it's called) I have the single HID kit and the focus is a little off, the fog shines a bit higher then the stock bulb and from what I could tell there is no individual aim adjustment for the fog.
Old Mar 19, 2007 | 07:34 PM
.moO^.'s Avatar
From my research on this board, there isn't a HID kit that has matching color as the stock OEM bulb......
My brother purchased his HID kit from (http://www.xenondepot.com/) the bulb and ballast is phillip made. I thought it was a bit pricy so I thought maybe there is a different source.
Old Mar 19, 2007 | 07:37 PM
Scootch's Avatar
www.plasmagarage.com
enjoy
Joe
Jusseth
Sep 13, 2020 12:25 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
as25656800
Aug 9, 2015 07:25 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
