Changing fog light, main light, hi-beams and side strip?
Mar 19, 2007 | 08:50 PM
I am interested in changing all the components of my lights. I understand the process of switching the main bulbs to a D2R bulb (6000 K in my case) but I'm unsure about what to order for the fog lights. Do I need a separate ballast? Also is it possible to change the high beams as well? I can't seem to find any posts that have that info.
I apologize in advance but I have been unable to locate a thread that has info for all components of the lights.
Reply 0
Mar 19, 2007 | 08:53 PM
fogs are H4, you can switch out to HID but you will need a kit which includes the balast. There are two types of H4 HID kits available a single light which will give you either fog or high beam (not both) or bi-light which includes a solenoid so you can switch between fog and high lights.
Reply 0
Mar 19, 2007 | 08:55 PM
Are you planning to put an HID bulb in the fog light area? If so, you would need a seperate ballast as well as HID bulbs for it. the normal fog light bulbs are halogen bulbs. They are H4 bulbs.
Reply 0
Mar 19, 2007 | 09:24 PM
Just realized the H4 kit at plasmagarage.com is dual beam. So if I install that kit, and change my D2R to 6000 K all my lights should match and be HID, right? What about the amber light? How and what do I change that to?
Reply 0
