inside cabin lights
inside cabin lights
hey guys, i want to change the cabin light bulbs near the sunroof to a bluish-whiter color bulb. saw a coupe guy had it, and it looked good.
what kind of bulb do i have to get, and how do i get the damnn thing to pop out to replace it? also, has anyone ever thought about changing the color of the bulbs under the door panel? so that when you open up the doors, you wont see the ugly pale yellow color anymore...but maybe a more nicer blue color.
any help will be appreciated.
most people get LEDs .. i forgot the number .. but all you need is a tiny flat head screw driver to pop off the cover ... be carefull though the clips are fragile... the ones under the door pop out with a tiny flat head also .. the wire isnt long enough for you to pull out the whole assembly .. so you gotta be creative
check out superbrightleds.com
superbright. i changed out every light on my car with them. including the strip in the headlight.. awesome. the color def. turns heads. i have gotten comment after comment about it
1 trunk = T13 wedge base LED
2 map light = 3022 X 9 LED Festoon Bulb
2 door Lights = 3022 X9 Led Festoon Bulb
4 Clear markers and Headlight strips = WLED 5-LED Wide Angle LED Bulb
2 License Plate = WLED 4-LED Bulb
i got all of these in white..
Originally Posted by Infinite_636
coo, thanks
you can buy a LED plate with 12 Leds on each side that are wired to use the factory bulb power supply!! they are cheap and bright! I will find you a pic!
Originally Posted by Jedunnigan
Those are really nice, do you have a link?
They are 30 shipped!
http://cgi.ebay.com/ebaymotors/ws/eB...m=160106560884
Originally Posted by clinthammer
damn they are neat but $30...
Then go here and pay more
http://www.evo-r.net/product/LED-DOME/index.htm
30 isnt shyt!
well i didn't know other places cost so much. i just found it expensive to pay $50+ for two pieces.
no need to get aggressive..
