I changed a LOT of bulbs to LED - PICS
Old Apr 19, 2007 | 11:39 PM
08G37TX's Avatar
I changed just about every light in the car including front and rear blinkers to LED. I already have my custom made front sidemarkers that were modded to LED. Here are pics of everything even the blinkers (which did need to have the Load Resisitors to stop hyper blinking). The sidemarkers are also modded to blink which you will see a second row of LED's that light for the blinking. From the video it looks like the front blinker is really dim. It is ONLY the angle, from the front it is as bright as stock.
Old Apr 20, 2007 | 01:45 AM
j-velocity's Avatar
How do I change the reverse lights?
I have tried to search but counldn't find the instruction.
Thx
Old Apr 20, 2007 | 02:03 AM
Calvin's Avatar
Overglorified Altima
^^you gotta remove the tailllights...there should be three bolts
youll need an 8mm..or was it 10mm? ugh..i forgot
Old Apr 20, 2007 | 02:07 AM
08G37TX's Avatar
Thx
You have to remove the trimp around the trunk latch and pull back the carpet. There are three nuts that have to be removed from the back in order to remove the taillight housing from the car.
It is a 10mm.
Hope this helps
Old Apr 20, 2007 | 05:20 PM
sfgr415's Avatar
What size bulbs are :
-front turn signal (in headlight)
-rear turn signal
-rear sidemarker (in taillight)
Thanks.
Old Apr 20, 2007 | 10:57 PM
Cobra-2-G's Avatar
are the dome lights just plug n play? If so, where, what, and how much!
Old Apr 20, 2007 | 11:49 PM
08G37TX's Avatar
-rear turn signal
Thanks.
Front and rear Turn signals are 7440
Rear Sidemarker is 168/194
Old Apr 20, 2007 | 11:56 PM
08G37TX's Avatar
Yes they are plug and play I ordered them from superbrightleds.com. They are the
3022-x4 LED Festoon bulb
30x10mm (1.181 inches long)12 VDC Festoon Base Bulb with 4 LEDS
Select LED Color
$ 1.89
But right now they are sold out of the white, or no longer carrying them in white. I had a set I was giving away on the boards a few days ago but someone snatched them up last night.
Old Apr 21, 2007 | 02:30 AM
RocketG35's Avatar
Why do I bother to DIY???
The 2nd video is exactly the same as the first one (front)...do you have a video of the rear blinkers?
Old Apr 21, 2007 | 04:43 AM
08G37TX's Avatar
Fixed Link
Old Apr 21, 2007 | 09:15 AM
Cobra-2-G's Avatar
Select LED Color
$ 1.89
Thanks.....and that sucks.
what is the reverse light ones?
Old Apr 21, 2007 | 12:02 PM
08G37TX's Avatar
Here are the reverse lights I got from superbrightleds.com
921-x9 Wedge Base LED bulb
921 Type with 9 LEDs, replaces 194/168 wedge base car bulbs
Available in White, Blue, Green, Red and Amber LED
measures 1.25 inch long by 0.60 inch diameter
$ 1.95 + $1.75 for White
Old Apr 22, 2007 | 10:10 AM
Cobra-2-G's Avatar
Thanks dude. I just got 1 of the dome LED's off of ebay, but that is all I could find. So I think I need 2 though, huh??
Old Apr 22, 2007 | 10:28 AM
Nismo G's Avatar
what bulb did you use for your license plate?
-Sean
Old Apr 22, 2007 | 12:10 PM
08G37TX's Avatar
Yes you will need two. Some people have had problems with the superbrightleds bulbs not matching. That is why I purchased 4 of them in hopes of having two that matched and all 4 did. That is why I had an extras set.
