Fog lights/high beams
Old Jun 25, 2007 | 10:50 PM
vstypicals's Avatar
I was working on the car last night and noticed that one of my fog lights was not working. I thought the bulb simply died. When I turn the fog lights on and off, the bulb doesn't light up, but when I turn the high beams on, they're both lit up.
I also noticed that when my fog lights are/were on, they give a "light yellow" color while the high beams give off a "dark yellow" color.. which is kinda weird since, If I'm not mistaken, the fog lights and high beams run off the same bulb.
NOTE: I have PIAA Plasma Ion Yellow bulbs.
Any ideas?
Thanks,
Jeff
Old Jun 26, 2007 | 12:38 AM
helldorado's Avatar
Your bulbs are dual filament. So the filament for the low beam (fog) broke while the filament for the high beam stayed intact. That's all.
Not sure about the color difference, though its probably voltage related. Never used the PIAA bulbs.
Old Jun 26, 2007 | 04:16 AM
vstypicals's Avatar
Is there anything I can do to salvage the bulbs?
Old Jun 26, 2007 | 12:08 PM
Calvin's Avatar
Overglorified Altima
once one filament is gone, it's gone.
Old Jun 26, 2007 | 03:07 PM
vstypicals's Avatar
I see. Alright. Any suggestions on replacement bulbs, ..yellow ones..?
Old Jun 26, 2007 | 03:13 PM
Calvin's Avatar
luminics
Old Jun 27, 2007 | 10:08 PM
vstypicals's Avatar
Turns our that there's a local place nearby that sells the Luminics H4 Yellow bulbs. I'll pick up a pair tomorrow.
Now onto the harder part, the last time I tried to change bulbs in the headlights, I ended up getting several little cuts on my hands, LOL. Anyone know an easier way to change the fogs without removing the front bumper? I have the Nismo front and I don't know how the shop installed them and where they drilled the screws..
HELP!
Old Jun 28, 2007 | 01:25 AM
Calvin's Avatar
reach your way through the fender well.
Old Jun 28, 2007 | 12:32 PM
sfgr415's Avatar
+1. It is a PITA if you have big hands but it beats taking off the bumper.
Old Jun 28, 2007 | 02:26 PM
jtrudeau's Avatar
Easiest access is to jack up the car put it on stands turn the wheel to the right if you are working on the left pull the two snap pins out and you will have easy access to the headlight/foglamps. If you want to change the the clearance bulb to some LEDs, now is the perfect time to do it since you'll be working in there anyways.
Old Jun 28, 2007 | 03:08 PM
vstypicals's Avatar
Who would've known that having small hands would be a good thing for once..
Old Jun 28, 2007 | 03:12 PM
jtrudeau's Avatar
I have big hands and thats why I have to jack the car so the suspension unloads.
Jusseth
Sep 13, 2020 12:25 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
Freddy07g35
Sep 17, 2015 08:53 PM
twentyeggs
Sep 11, 2015 03:58 PM
attarday
Jul 15, 2015 04:03 PM
