LED door handle glow
Old Dec 20, 2012 | 05:12 PM
  #31
GMoney022's Avatar
Originally Posted by kennymo
i dont have a write up on how i did it but i can easily tell you how to do it.
its easiest if you have an aftermarket alarm. because then you can hook it straight up to the brain. you would need to look up the wiring diagram for your alarm and look at which wire coming off the harness is for the domelight. then from there you want to tap in a wire and run it to a 30/40 relay (just to protect the alarm itself) hook up the relay exactly how the dome light relay in the wiring diagram is hooked up. only instead of the dome light you would hook up the LEDs. then run the LEDs to each door or wherever you want to put them. i used these...http://www.oznium.com/prewired-surface-mount-led. they have a waterprood strip running up to the LED itself. and then there is double sided tape on the back of the LED. run the LED through the back of the handle and use the double sided tape to attach it to the inside of the handle like where your hand would grab to open the door. whenever you turn your alarm off the handles will light up. and then they will go off again when ever your dome light goes off.
why couldn't you tap in into the dome light wires at the BCM? the dome lights go on and off when you unlock/lock the car i feel like that would be easier. Great link btw. For $4 a piece how could you go wrong for such a small but sick mod
VatoVazq
Steering & Suspension
16
Jan 3, 2025 11:08 PM
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Gabe83714
Oct 6, 2015 06:40 AM
