1 headlight not working
Old Aug 1, 2007 | 03:36 PM
johne's Avatar
i bought a new zenon bulb but it wasnt the problem.because theres only a few of these cars here in the uk and i dont know wherethe fuse is or if there is one for each headlight.has anyone else had this situation.any help would be appreciated.im wondering if i have a bad earth
Old Aug 1, 2007 | 03:49 PM
redlude97's Avatar
How do you know its not the bulb? Did you try switching the bulbs from side to side? If its not the bulb, then it may be the ballast/ignitor. If it was the fuse, I would think both sides would be out
Old Aug 1, 2007 | 04:06 PM
sfgr415's Avatar
Did you swap bulbs to check? If so, then it is probably your ballast.
Old Aug 3, 2007 | 08:57 PM
johne's Avatar
i swopped the bulbs and it worked on the other side.ive never herd of a ballast ignighter what and where is it can i get one and can i fit it myself.
Old Aug 3, 2007 | 11:20 PM
sfgr415's Avatar
the ballast is the grey piece at the bottom of the headlight assembly. it is the igniter for the HID bulbs. there are 3 screws that hold it on the headlight housing. there is one harness on the outside (i believe green) and another on the inside (i believe brown). there is also a ground cable inside.
Old Aug 4, 2007 | 01:26 AM
johne's Avatar
balancer
can you get to it from the inner wing or does the headlight have to come out.will i have to buy it from a main dealer or one of the companys on the website. and last of all are they exspensive
Old Aug 4, 2007 | 11:27 AM
sfgr415's Avatar
you have to remove the headlight. it is all the way at the bottom. and i'm pretty sure you would need a direct replacement. check ebay.
Old Aug 4, 2007 | 02:14 PM
johne's Avatar
ballast ignightor
wow i just priced it up at nissan uk and if it is the same thing they called it a control unit i think ill have to remortgage the house .other than ebay could i get one elswhere .and has anyone got any idea how much they are in the usa.
bTanz
Oct 15, 2015 02:31 PM
EPG35
Aug 16, 2015 04:52 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
attarday
Jul 15, 2015 04:03 PM
