Clearance lamps - LED swap
Old Aug 12, 2007 | 11:13 PM
GeorgeRex's Avatar
I bought some 9 LED SMT II 168 bulbs recently and stuck them in my clearance lamps. While a tad blue for perfection(less blue than the middle picture), I think it looks a lot better than the incandescent bulb and when viewed from the side, the multiple LED elements look interesting. It was hard to photograph but here are some pics.
Old Aug 13, 2007 | 12:09 AM
That G Gray's Avatar
cleaannnnnnnn
Old Aug 13, 2007 | 12:15 AM
Calvin's Avatar
Overglorified Altima
looks much better.
Old Aug 13, 2007 | 01:59 AM
G-Ride Canada's Avatar
looks way better!! will this work for the coupe as well?
Old Aug 13, 2007 | 06:11 PM
WaLLy's Avatar
much much better!
Old Aug 13, 2007 | 06:13 PM
WaLLy's Avatar
yup, you can either use a 168 or 194 bulb for the city light.
Old Aug 14, 2007 | 12:45 AM
Red_G35's Avatar
I dont see what you've done?
I thought you can only use H4 bulbs in there? Fog/High beams only.
Can you post a link to the bulb you bought?
Old Aug 14, 2007 | 03:47 AM
lovely! I will get to it soon as possible!
thanks!
Old Aug 15, 2007 | 10:37 PM
GeorgeRex's Avatar
I replaced the small bulb in the inner side of the center headlight housing with an LED. It's called a city lamp and the bulb is the same size found in side markers and some turn signals (168 / 194). It does not replace the H4 bulb.
Turn your lights to the park position and you will see the bulb turn on that I am referring to.
Old Aug 16, 2007 | 12:27 AM
Red_G35's Avatar
Oh, very cool. I never noticed. Looks great. Are they on coupes as well? Are they hard to reach?
Thanks!!
Old Aug 30, 2007 | 06:05 PM
VancouverG88's Avatar
these lights are only in the 03-04 g35 sedans. on 05-06 sedans, the turn signal is used as the clearance light. on coupes, the clearance light is the long vertical strip thing i believe
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
Gabe83714
Oct 6, 2015 06:40 AM
doakley92
Sep 25, 2015 12:58 PM
