i just did this mod in like 45 mins.... it looks great... and its makes your g35 safer
I did mine this morning. Took about 45 minutes for the passenger side while I figured out how I wanted to do it, and maybe 15 for the driver side. Mine is basically invisible except for the wire splice up near the main headlight connector. I soldered and wrapped the wire extension and put it back in the sleeve.
BTW, I had a Purple/White wire on the passenger side and Green/White on the driver side (05 Sedan). I think I'm going to do the rear marker as well.
I will definitely have to do this sometime
Thanks guys for providing some good info
Thanks guys for providing some good infoRegistered User
Just did this in about an hour, really easy to do. It looks great with my LED's
Does anyone know if you can do this with the rear tail lights?
You probably can do it with the rears. I'm looking in to it. BTW, what LED's are you running? I bought some 11 SMT bulbs from v-leds.com, but I'm not real happy with how they look, so I'm back to the stock amber bulbs in my clear corners. I want the entire lens to be filled with color, and the LEDs were either very intense or almost non-existent.
I'm using LED's from V-leds. I forget which ones exactly but I'll check when I get home.
I might try to do the rears today. I'm thinking that the same theory from the front could be applied to the rear?
I just did this mod yesterday evening. I been meaning to do it since I got the JDM clear corners with the "bump". finally figured I would do it since I was changing the oil too.
Thanks for the info everyone!
Buckeye, I'm using the license plate LED's they offer.
http://v-leds.com/Exterior-LED/Corne...81133-1-2.html
I also just did the rears, looks a lot better
I'll be posting a DIY tonight.
I'll be posting a DIY tonight.Registered User
check out my led corners w/ blinkers. PM me about details as well
https://g35driver.com/forums/media-s...inker-mod.html
I want ambers for the side lights, but those probably look good. Here's the license plate bulbs I got: http://v-leds.com/Interior-LED/DomeM...68710-1-2.html.Originally Posted by cc_brandon
Buckeye, I'm using the license plate LED's they offer. http://v-leds.com/Exterior-LED/Corne...81133-1-2.html
