Front side marker as the Turn Signal
Old Sep 7, 2007 | 06:19 PM
rocsell's Avatar
Has anyone ever moded the fron side marker as the turn signal?
The downside, I think, is that you no longer had a side marker (no light from the side) until you change lanes/turn....just looking to see if this can/was done on the coupe.
Old Sep 7, 2007 | 06:42 PM
in2win's Avatar
yes search, there is a do it yourself thread with pictures that looks somewhat easy to do. It shows it step by step and the supplies needed.
Old Sep 7, 2007 | 06:56 PM
RST531's Avatar
here it is:
updated link, old one in the DIY is no longer working.
http://www.6mt.net/mod-g35-sidemarker.php
i wonder if anyone tried this with the clearance strip for the 03-05 headlights??
Old Sep 7, 2007 | 07:59 PM
Triple8Sol's Avatar
You should be able to wire up the side bumper lights so that they stay on as usual, and then blink with the usual sidemarkers.
Old Sep 7, 2007 | 08:15 PM
AthensBlueG's Avatar
Brian
Yes, I've done it to my car using the above DIY that RST531 linked. I forgot about that mod, even though I have it. lol
You need to splice a wire.
Old Sep 8, 2007 | 08:51 PM
rocsell's Avatar
COOl!!!
Thanks guys...I officially took title bringing my 06 coupe across the border yesterday and look forward to using this forum
Old Sep 9, 2007 | 11:25 PM
2K6G35's Avatar
Originally Posted by RST531
here it is:
Thanks, I just did this on my car about an hour.
I didn't remove the wheels or use the extension wire. It's much cleaner IMO!
Here are my DIY:
  1. Jag up the car (you don't need to removed the wheels!)
  2. Remove all 5 plastic lug nuts using flat screwdriver
  3. Remove all 8 screws from underneath the bumper connecting the Wheel Well Lining.
  4. CAREFULLY, pop out 2 plastic log nuts holding from the bottom of the lining in place.
  5. Once all remove, loosen Wheel Well Lining & remove it off the car so that you can see the cables/wires
  6. On the main lighting wire harness (look just behind the headlights, and you'll see a bunch of colored wires), carefully cut the plastic tape that covers the main light wire harness & the side marker wire harness using a sharp blade.
  7. Once removed, you will see the side marker wires (Black & Purple) and all the headlights wire harness.
  8. Now cut the Black side marker wire next to the headlights wire harness and make sure you cut it closer to the wire that you will need to clam it together with.
    • For Passenger side: purple wire with a white stripe
    • For Driver side: green wire with a white stripe
  9. Before you put everything back on, test the lights.
  10. Once everything works fine, you can put them all back.
  11. Repeat for the other side.
Good luck!
Old Dec 29, 2007 | 02:17 PM
lexusk8's Avatar
2K6G35, I have a question on step #8. When you tap the black side marker wire to the purple/green wire, how exactly is that done? Is it done by wire splice or with a wire tap device? I'm bit of a novice in electrical work but I like to be able to tackle this project on my car.
Old Dec 29, 2007 | 03:29 PM
FlSHRFun's Avatar
http://clearcorners.com/products/inf...35_1c/f_smark/
They charge quite a bit but they do an excellent job.
You can keep one row on with your parking lights and another row that will function as a blinker.
If you don't want the hyper white, I'm sure you could ask them to make two rows of amber, parking lights to be dim and signal lights to be bright.
Old Dec 29, 2007 | 03:32 PM
Calvin's Avatar
Overglorified Altima
Blinker mod ownz clearcorners.com's side markers, IMO.
Old Dec 29, 2007 | 03:50 PM
dofu's Avatar
20 Year Member
http://www.radioshack.com/product/in...ductId=2104093
Or you can hardwire it, sauder it, etc...
Old Dec 30, 2007 | 08:54 PM
MidnightG35X's Avatar
You could attempt to make your own.
https://g35driver.com/forums/lighting/133672-led-parking-blinker-clear-corner-teaser.html
Old Jan 4, 2008 | 01:47 AM
2K6G35's Avatar
You just tap it with this
You can get it from Homedepot or Radioshack for $0.10 /each
I didn't see Dofu's post above. He beat me to it.
Old May 16, 2008 | 02:21 PM
OH6 G35's Avatar
How can you make the Turn Signal and the Side Marker alternating Lamps?
Old May 18, 2008 | 06:29 PM
dofu's Avatar
20 Year Member
They automatically do that if you use the 6MT write-up.
