piaa fuse ?
Old Sep 13, 2007 | 12:10 PM
Boostedef's Avatar
piaa fuse ?
Hey I just got a new set of headlights and they came with piaa
super terra 5500k wedge leds and piaa xtreme force H4 4700k for the fogs
theres this fuse looking type thing with what looks like a resistor inside added into the red/green (power) wire coming from the clearence strip bulb and has to butt connectors on it what is it ?
Old Sep 13, 2007 | 12:52 PM
GR8TG35's Avatar
I believe you answered your own question.
The part you are holding looks like a resistor, which I believe is necessary for the PIAA super Terra wedge LED's to operate. It may cause interference with the normal flashing operation of your signals without it, that is if I remember correctly......they were all the rage because of there brightness sometime back.
If you change out the LED, then you can remove that from the circuit and install regular LED's or 168/194 bulbs.
Old Sep 13, 2007 | 01:55 PM
Boostedef's Avatar
thanks the blue and white connectors threw me off I thought something went into them or out you know what i mean lol
G35-R
Nov 7, 2015 01:21 PM
Learned Hand
Oct 1, 2015 09:02 AM
yosip1115
16
Sep 28, 2015 04:14 PM
2014g35x
Sep 11, 2015 07:53 PM
twentyeggs
Sep 11, 2015 03:58 PM
