quad retro attempt
Old Nov 14, 2007 | 09:30 PM
Retzius's Avatar
Here are some pics of my modded TL/ZKW replica lenses. The pics were taken at about 23-25ft. I just bent the TL shield a little from the inside. Let me know what you guys think.
TL/ZKW replica slant @ about 25ft. bent shield slightly
TL/ZKW replica slant @ about 25ft. (close up)
TL/ZKW replica step up @ about 25ft.
TL/ZKW replica step up @ about 25ft. close up
Old Nov 14, 2007 | 11:26 PM
1star2's Avatar
Originally Posted by Retzius
OMGosh I got a response!
I was wondering why I had so many views but no responses.
I am still not done working on the headlights. I have one pretty much done but I need a little more work. I am going to have a G35 with clear TSX lense mod at the top (aka single xenon) and a (Bi-xenon) Acura TL/ZKW replica on the bottom or foglight area.
Thanks ttrank, I do have to admit that I got a kick out of color modding them.
Isn't the factory '06 G35 xenon a bi-xenon? Does this change when you do the TSX lense mod? I am curious because I am thinking of trying this mod myself.
Old Nov 14, 2007 | 11:30 PM
Retzius's Avatar
G35 bi-xenon can retain its full function if you try the mod. You should try it out.
Old Nov 15, 2007 | 12:29 AM
redlude97's Avatar
The TL's look much better now at that distance
Old Nov 15, 2007 | 12:35 AM
Retzius's Avatar
Yeah, a very, very slight shield bend forward or down did the trick
I might try and get the slant one a little more sharper but it good enough for me right now.
Old Nov 15, 2007 | 01:12 AM
godmans's Avatar
NO NO ..
you are tempting me to re-do my retro to make it a quad setup
but really nice progress so far
Old Nov 15, 2007 | 01:19 AM
Retzius's Avatar
DO IT! DO IT! DO IT! Its hasnt been that difficult but I have yet to try and aim them so I can't fully say. I'm still waiting for some parts before I try to aim.
Old Nov 15, 2007 | 11:28 AM
IvoryGT's Avatar
that looks about right.
Old Nov 15, 2007 | 12:29 PM
Retzius's Avatar
Hey Ivory,
Do you think its still possible to go sharper on the cutoffs? Thanks.
Old Nov 15, 2007 | 01:26 PM
IvoryGT's Avatar
if you try spacing out the lens a bit you might get slight better results.
Old Nov 15, 2007 | 01:41 PM
Retzius's Avatar
Do you mean like actually adding a rubber/carboard spacer to the lense?
If so, I can give it a shot.
Old Nov 15, 2007 | 01:50 PM
IvoryGT's Avatar
yeah very thin spacer
Old Nov 15, 2007 | 02:37 PM
ttrank's Avatar
Grocery getter
Where did you get your ZKW replica?
I got a set of 330xi projectors off ebay that I was sure had the ZKW but they are still fuzzy at the center of the lens so I still have somewhat of a hot spot in the center of mine. Yours already look better than mine for sharpness, mine have more color but I would like to get rid of the center blur and don't want to spend another $200 on real ZKW's. I have too much in these headlights as-is!
Thanks
Old Nov 15, 2007 | 03:04 PM
Retzius's Avatar
If your lenses are clear then it is possible to achieve a sharp cutoff.
I would try to bend the shield very lightly or rotate the lense. When I mean bend the shield, that means put a small amount of pressure on the shield with your finger. I know the TL shield is stiff but small amounts of pressure are better.
I got my ZKW replicas from IvoryGT.
Old Nov 15, 2007 | 03:08 PM
  #30
Retzius's Avatar
Thanks
Oh yeah, post a pic of your cutoff here
