Lamp Replacement Guide
Old Sep 18, 2008 | 10:14 AM
Rhino_111's Avatar
Originally Posted by UR2EZ
turn signal and sidemarker HAVE to be amber....
Only if you want to be boring and legal.
Old Sep 18, 2008 | 10:25 AM
Calvin's Avatar
Overglorified Altima
turn signals can be white in california. and if i'm not mistaken, clear corners are ok. the bulbs need to be amber, however.
Incorrect color of turn signal. It must be white or yellow to the front, red or yellow to the rear (24953 VC).
Illegal color of side marker lights. If present, must be yellow in the front and red in the rear (25106, 24003 VC).
http://www.chp.ca.gov/community/streetlegal.html
*note: yellow = amber
Originally Posted by mpapers
hey are the H1 and turn signal 7440 bulbs on the 07 headlights clear or orange? Is clear illegal?
stock h1 bulbs are regular halogens. they're yellowish. turn signals are amber coated.
03-04 Sedan lamp replacement guide:
http://www.autotalk.com/how-to/infin...ion-guide.html
also, the Vanity light is 31x5mm festoon bulb..
also note, 194 and 158 are the same bulb
194 and 168 are the same.
Old Sep 18, 2008 | 11:37 PM
The-Dream's Avatar
What bulb does the clear corner use?
EDIT: Nevermind I found out.
However what does dual-filament mean? Does it mean I can't use just any H4?
Old Sep 21, 2008 | 10:55 AM
G U LATER's Avatar
which one is the map light
Old Sep 29, 2008 | 06:28 AM
Dranom's Avatar
any one know what bulb this is?
its from the glove box. i wanna change it to LED if possible coz this thing sucks big time!
Old Sep 29, 2008 | 12:14 PM
Calvin's Avatar
looks like an 194 or 168 (they're the same thing).
Old Sep 29, 2008 | 03:37 PM
Dranom's Avatar
its smaller than a 168 though
Old Nov 7, 2008 | 05:46 PM
SteveZ's Avatar
What do you call the light in the narrow section next to the headlight? It's a small bulb in the strip outboard side of the headlight assembly:
I can't find a listing for the bulb, just an Infiniti part number. Owner's manual says take it to the dealer to replace it, no thanks
Old Nov 30, 2008 | 02:19 PM
albundy's Avatar
sorry if this sounds dumb or has been answered..i have a 04 sedan with hids..now in the manual it talks about fog lights, which from my experience are normally by the bottom of the bumper. So in the sedans case i am under the impression they are in the same housing as the headlights?? and if that is true are they the non hid looking lights? and lastly what # are they? thanks in advance
Old Dec 16, 2008 | 05:08 PM
ttrank's Avatar
Grocery getter
FYI - the sedan guide is in the sedan section FAQ.
Old Mar 14, 2009 | 11:13 AM
bigm789's Avatar
Will changing to LED blinkers, sidemarkers, etc cause them to "blink fast"?
Old Apr 27, 2009 | 09:11 PM
exwrx's Avatar
is the fog light bulb for a 2004 g35 sedan a 9003 or h4?? thanks in advance.
Old May 15, 2009 | 01:17 PM
IMAG35's Avatar
I have 2 sets of Polarg H4 4500K alpha white bulbs for sale if anyone is interested. Brand new, never opened package. PM me if you're interested.
Old May 17, 2009 | 10:48 PM
xplosive9z's Avatar
I checked on Sylvinia's website for what bulb size our door lights are (08 sedan).. it says we have DE3022... i pulled the bulbs out of the door lights and they look like license plate bulbs, not the fuse type.. i went on vleds.com and i couldnt find which one it is.. i dont want to order it, wait for them to come and they dont end up fitting..
does anyone know which is the correct bulb on vleds?
Old Jun 8, 2009 | 01:30 AM
  #30
CalRSX07's Avatar
how much should i expect to pay to have one single headlamp bulb replaced (for labor)? what's the best place to have it done if i don't want to do it myself?
