05-06 sedan tail lights aftermarket replacment
Old Jan 11, 2008 | 04:34 PM
03Sg35's Avatar
Well Im fuming a little I got my some tail lights from 05 for my 03. I had them set ona bench in my garage, during some work I was doing i knocked one light off the table, it fell and cracked.
My question is light I broke was oem, light i found to replace it is oem replacment quality. Will this light be any diffrent from oem quality wise. if I have this light next to oem ones will you see diffrence beween the two. Thanx
Old Jan 11, 2008 | 04:39 PM
G SEDAN's Avatar
i wasn't aware they even had an OEM replacement quality tail light for the 05-06. I would imagine people would buy that instead of OEM as the 05-06 lights are in much demand by the 03-04 crowd. I wouldn't mix and match to be honest with you...
93 til Infiniti's Avatar
OEM Replacement quality? Like an Ebay knock-off?
Im sure there will be a difference in craftsmanship? There's always a reason why those parts are cheaper than the OEM ones.
Only one way to find out....install them, post pics & show us.
Old Jan 11, 2008 | 04:45 PM
RADIOGUY21's Avatar
yeah i personally wouldnt chance it with an aftermarket. If the one you broke was a used OEM, your probably going to see a difference between the other used one and a new aftermarket one. IMO, if you order an aftermarket make sure they have a good return policy just in case you decide you dont want it. Your probably best finding another 05-06 OEM one from a junk yard, if possible.
wreckeds2k's Avatar
im on the phone with Keystone checking for you..
Old Jan 11, 2008 | 04:47 PM
wreckeds2k's Avatar
175 New aftermarket from Keystone.. I get good deals through them but not sure if this is that great of a deal.. Let me know.
wreckeds2k's Avatar
PATRIOT AVATAR, make it $300
J/K
Old Jan 11, 2008 | 04:54 PM
Jason@Riverside's Avatar
$480 Shipped out side of california for a complete set of 05-06 sedan lamps w/ reverse housings...
a single brake light assembly on its own is not that much... :-/ ???
Old Jan 11, 2008 | 05:11 PM
03Sg35's Avatar
Thanx for the info, I have Keystone account also, have some stake in a import shop in CT. Im looking for the cheapest way to replace the broke light bur I dont want them looking off. I guess I can tint them if they are diffrent. Thanx fellas and GO PATS!!!!!!!!!!!!!!!!!!!!!! prediciton Pats 38 Jags 14
Old Jan 11, 2008 | 05:19 PM
$188 for a new OEM part... my forum price...
Im not sure if $13 is worth it to me to have a possible inferior product...
Old Jan 11, 2008 | 07:05 PM
G35Papa's Avatar
I purchased OEM replacement headlights from ebay and the quality is NOT the same. Inferior compared to OEM. I would bet the light output is different between the two.
IMO, stick with OEM. Good luck
Old Jan 11, 2008 | 07:38 PM
redlude97's Avatar
The LED's will be different I guarantee it, and they will look different when lit up
Old Jan 11, 2008 | 08:01 PM
03Sg35's Avatar
Jason you got pm
Ludz
Lights
Mar 28, 2016 02:06 AM
JG_G35
Lights
21
Sep 14, 2015 02:00 AM
myaso
Lighting
Jul 22, 2015 10:34 PM
