Lights for G35 Coupe
Old Apr 7, 2004 | 02:54 PM
havok5414's Avatar
I have a G35 coupe and want to replace all of the lights and am really confused. I was wondering if some wonderful person could just list what bulbs he used for each of those in order to match the xenons:
Front turn signals
High beams
Clearance Light
Corner lights
I know for the corners I need to get the clear corners but What bulb can I get for them to be matching with xenons.
Thank you.
Old Apr 7, 2004 | 03:10 PM
DUNBAR's Avatar
Re: Lights for G35 Coupe
https://g35driver.com/forums/showfla...sed&sb=5&part=
04, 6mt, Twilight Blue, Premium, Aero
Old Apr 7, 2004 | 03:25 PM
Hey_Ya's Avatar
check with ares on my350z.com. He sells leds for some that you are looking for that match the xenons very closely.
2004 Diamond Graphite Infiniti G35 Sedan
Z Intake Tube
5% Tint
ZAINO
Old Apr 7, 2004 | 03:55 PM
av8r's Avatar
That thread is nice and all, but it does not show the bulb numbers. Yeah the HID number is shown but in all the other lights, it just shows the wattage.
2004 Sedan 6MT
Silver/Graphite/Premium/Aero
HuperOptik Ceramic 50/Clear Corners/XM Radio
Z-Tube/Stillen High Flow Airbox/Grounding Kit
Old Apr 7, 2004 | 09:53 PM
SFLG35's Avatar
FGC President
well since i nice and wonderful g35driver.com member, i thought id help you out. these threads should help your decision makin process a lot easier.
Lights!
Lights - The Final Answer
Matching Fogs To HID Color
as for the clearance and the corner lights, they are both the same bulb. i believe they are 192 or 164 wedge bulbs. not for sure though cause i used piaa leds in both of mine.
the front turn lights i dont really see a point in changing those unless you have cleared them out, so i dont know what type they are. they will be orange not matter what bulb you put in there, but i am pretty sure there is a link to a chart in one of those threads that gives you all the bulb numbers you will need.
Daniel
5ATc / DP / Premium / Aero / Clear Bra / 5% Tint - 30% Windshield / Ground Kit / Clear Corners / Shock Sensor / L.E.D. Hood Lights / Z - Tube / OEM Remote Window Up semi-fixed and installed
Old Apr 7, 2004 | 11:27 PM
havok5414's Avatar
Finally I have the answers to my own questions. Thank you all for your help.
The clearance and corner bulbs are 168 wedge bulbs or 168 LEDS.
The Fog/ highbeams are H4's. The one that is already a xenon is an H1, but I don't need to change that.
I have such a bad headache from reading every single one of those threads, but I'm happy I know about it and confident in my choice of bulbs. Thank you all.
Jusseth
Sep 13, 2020 12:25 PM
mike730
Jan 12, 2018 04:25 PM
mjfenix
Jul 24, 2015 05:16 PM
igking
Jul 19, 2015 01:12 AM
attarday
Jul 15, 2015 04:03 PM
