Question about some hid bulbs I got
May 1, 2008 | 03:39 AM
So I got some supervision 8000k hid bulbs from a friend. The box says d2s and I have d2r's, but the guy that gave em to me said it works for both. I know they will fit, but they dont have that mini reflector inside the bulb. So would there be any problems with using these bulbs? too much glare ? Btw, does anyone have experience with these super vision bulbs ?
Reply 0
May 1, 2008 | 03:42 AM
if you have the d2r then that means g from 06-up the d2s are from 03-05 so therefore they wont fit. as far as i know.. if you get the d2c they fit for both.
Reply 0
May 1, 2008 | 03:51 AM
Do NOT use those in your reflector housing. They will cause alot of glare for other drivers and make you a douchebag
Reply 0
May 1, 2008 | 09:20 AM
^+1
Reply 0
May 1, 2008 | 02:53 PM
Quote: Do NOT use those in your reflector housing. They will cause alot of glare for other drivers and make you a douchebag
HAHAHA!!!
Reply 0
May 1, 2008 | 04:43 PM
There is a different notch on both bulb bases, so you would have to add/adjust a notch to fit.....but it would blind everyone coming towards you, so I say just exchange them for the right bulbs.
Reply 0
May 1, 2008 | 04:46 PM
Hahaha, so I guess I fall into the duchebag category.
Reply 0
May 1, 2008 | 04:50 PM
Quote: Hahaha, so I guess I fall into the duchebag category.
If you used bulbs without the ceramic shielding that d2r bulbs are supposed to have in your reflector housings, then yes it does.
Reply 0
May 1, 2008 | 04:55 PM
nevermind , mine have the ceramic sheild, just 10k though.
Reply 0
May 1, 2008 | 05:52 PM
must be kinda dim with 10K
Reply 0
