Headlight Removal Question! HELP!
ok so i looked at that stickied thread about removing headlights and thats great and all but it doesnt say HOW to unclip the wiring from the headlight and the car. how on earth do you disconnect them? currently my g is in my garage with the bumper off and the headlights unbolted so i need to figure this out asap. i dont want to break anything so i am afraid to force it. what do i do?!
I did this last weekend, the harness is a pain in the *** to get out. Try turning your driver side headlight inward towards the center of the car so the bottom part with the harness is angled outwards towards the fender; it's kind of hard to describe and it will take some jiggling to get it loose, but rotate your headlight that way until it slides out and you can see the bottom of the harness. There is basically no way to get the harness apart if you cannot easily reach the bottom of the harness where the clip is.
You can search one of the DIYs here that shows the headlight in this position, but I can't remember whose DIY it was but the pictures had a twilight blue G35 in it.
There should be something like |_| on the bottom of the harness, and you just put a flathead screwdriver down on it and pull. It should come apart with some force.
The passenger side is a huge pain because there isn't as much length to the harness wire so you literally cannot rotate it out. I had to get my girlfriend with tiny hands to get in there and use a screwdriver with a pivoting head to press down the harness clip. I have no idea how a full sized male would ever be able to do this so good luck.
ok so the "harness" is the black thing that you can turn and it holds the bulb? and the harness WIRE is the wire that goes to the plug that you need to disconnect?
The harness doesn't hold any bulbs I'm not sure what you are referring to.
lright i got it. how do i remove the ballast?
But here's a reference for you.
https://g35driver.com/forums/body-interior-exterior-lighting-diy/172562-diy-ballast-switch-06-headlight-upgrade.html
Post #11
alright I figured all that out. but here's another question...i have the hid bulbs to put in the fog lights...what else to I need/need to do to successfully switch it out?
