Need info with HID Bulb Replacement
Old Aug 29, 2008 | 06:47 PM
janz75's Avatar
I want to replace my stock HID headlights. Can I just replace the bulbs with a higher output bulbs like the 10,000K HID bulbs? Or do I need to replace the ballasts as well?
Old Aug 29, 2008 | 06:56 PM
redlude97's Avatar
10,000k bulbs aren't higher output, they are actually alot worse than stock
Old Aug 29, 2008 | 06:57 PM
SxExCx's Avatar
the K rating determines the color
Old Aug 29, 2008 | 06:58 PM
SxExCx's Avatar
most people will go with a 6000k setup because it is a very white color output
Old Aug 30, 2008 | 12:33 AM
janz75's Avatar
Ah ok...But but back to my question..if I want to replace the stock HID bulbs, do I need to replace the ballast as well or can I use the stock ballast if I want to change it to a different setup?
Old Aug 30, 2008 | 12:36 AM
caskyline's Avatar
Former Vendor
If you just change out the bulbs, you do not need to change the ballst.
6000k is a good choice
Old Aug 30, 2008 | 01:56 AM
SVLRx's Avatar
Change just the bulb, depending on your headlight, (projector or not) it'll be a D2s or D2r, D2c's work in either... 6000k is very white, 8000k is blue anything passed that is retarded...
Old Aug 30, 2008 | 12:00 PM
TN G35S's Avatar
Sorry to threadjack, but I've been searching for an hour. I'm finding all sorts of posts about bulb types, but can anyone tell me what color the stock HID's for an '08 are? I've seen some people putting aftermarket 6000k bulbs in, so my guess would be 4500k or so?
Thanks in advance...and sorry if I just overlooked an obvious thread.
Old Sep 21, 2008 | 12:55 AM
acerob90's Avatar
hey quick question man i have a 04 coupe g35 , i looking to change my lights to 6000k do i need to change wholething or only bulds ?
Old Sep 21, 2008 | 01:12 AM
OBG35's Avatar
^ read the whole thread and you will see your answer...
Old Oct 14, 2008 | 10:02 PM
G35-M6's Avatar
is there a way for me to check if its my ballast or is it my bulbs that is fried?
my car has 45000 miles... the driver side bulb didn't lit when i turn on my headlights.
i don't want to buy the bulbs and figure out i need the ballast instead. or i want to make sure its not my wires being messed up or i hope if its the fuse, it can be something easier, where do i access the fuse?
as25656800
Aug 9, 2015 07:25 AM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
vstypicals
Jul 20, 2015 10:55 PM
attarday
Jul 15, 2015 04:03 PM
