Rear TailLights LED not working
Old Sep 6, 2008 | 07:42 PM
sk8bo4rdv's Avatar
Exclamation Rear TailLights LED not working
ok so i just realized that an LED in my taillights isnt working like its suppose to be. the led that on the side of the tail light isnt turning on in my taillights, and not just one in both of them. does anyone know wat the problem could be?
ohh by the way i have 05 coupe tail lights. Thanks
heres some pictures of what i was talking about. does anyone know what the problem could be???
Attached Thumbnails Rear TailLights LED not working-rear-light.jpg   Rear TailLights LED not working-rear-taillights.jpg
Old Sep 6, 2008 | 07:51 PM
(>")> G35's Avatar
Seems like the bulbs may have burned out, start by pulling them out and taking a look at the filament. Yes, the sides are incandescent...
Old Sep 6, 2008 | 07:54 PM
madmike1029's Avatar
i may be wrong, but I think that part uses regular bulbs. They may be burned out and need to be replaced.
Old Sep 6, 2008 | 07:55 PM
sk8bo4rdv's Avatar
how do i pull out my taillights and wat kinda bulb goes in there??
Old Sep 6, 2008 | 08:33 PM
JOEYD0730's Avatar
they are #194 bulbs. you will need two total, one fo each side, not led's you can get them anywhere.
there is 3 8mm nuts holding each tailight in. two in the corners and one more towards the center of the trunk.
you will have to remove the rear carpet section. just be careful when you pop out the black holding clips, make sure you pull the center of the clip first then the whole clip comes out
its very easy to change, shouldnt take more than 5 minutes per side
good luck
Old Sep 6, 2008 | 08:36 PM
sk8bo4rdv's Avatar
Originally Posted by JOEYD0730
they are #194 bulbs. not led's you can get them anywhere.
there is 3 10mm nuts holding each tailight in. two in the corners and one more towards the center of the trunk.
good luck
ok thanks bro.
i still gotta learn how to take the tail lights off cuz im sooo bad at doing this kinda stuff.. haha
Old Sep 10, 2008 | 05:22 AM
psedog's Avatar
Back in SD**
It's funny how they used normal lights on the sides for the coupes, but led's for the sedans. Why? If you go through our manual, it can get confusing, since both coupe and sedan parts are listed and you can easily look at the wrong one and assume you are looking at the right one.
rezendvous420
May 31, 2020 01:26 PM
Kz_Ed
19 Inch
Oct 16, 2015 10:32 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 01:59 PM
