Broken Tab Headlight Question/Help!
Old Dec 4, 2008 | 11:11 AM
visibiliti's Avatar
Summary: Received pair of 07 projector headlights, tab on driver's side headlight broken. Something broken/rattling inside passenger side headlight, didn't have time to figure that one out before work.
1. Almost 100% sure the tab broke off in shipping due to how sender packaged it (or lack thereof )
2. Attached are pictures of the broken tab and how the tab should look
3. Am I SOL or is there a way to fix this? Looking for any and all solutions here.
4. I am assuming that all tabs are crucial in mounting the headlight, otherwise they wouldn't exist. Is this true?
Thank you and I will update this post about the problem with the passenger light when I figure out what broke inside.
Attached Thumbnails Broken Tab Headlight Question/Help!-brokentab.jpg   Broken Tab Headlight Question/Help!-correcttab.jpg
Old Dec 5, 2008 | 10:27 AM
visibiliti's Avatar
After messing around with the passenger side light a bit more and inspecting it closer, I still can't get whatever it is inside to slip out the back... nor can I see anything broken. I guess I won't know until I bake it apart?
Any ideas about the tab anyone?
Thanks
Old Dec 5, 2008 | 01:31 PM
ON's Avatar
ON
That tab will hold the front end of the fender, so I'm sure you'll need it. Did you buy it new from a store? If so, why not have them replace it. If you bought it used...you could try to use JB weld and put it back together. I'm sure it'll hold.
Old Dec 5, 2008 | 03:48 PM
visibiliti's Avatar
Bought it used.
I just searched JB Weld... wow I never knew that stuff even existed! Thanks for the suggestion... it sounds like that stuff will definitely do the trick... Im so relieved!
Any other suggestions still welcome, Ill be checking back on the thread and posting updates as they come.
Old Dec 5, 2008 | 04:26 PM
PPGFREAK's Avatar
There is a ton of stuff that will work for that, SEM, Fusor, and JB weld. Here is the thing that will make it work or not. SAND BOTH PIECES THAT YOU WANT TO STICK TOGETHER! 80grit to 320grit then clean to get off the dust,dirt,wax,grease,ect.
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Batfinity
Lights
Sep 27, 2015 12:29 AM
