changing headlight bulbs
Old Mar 15, 2009 | 12:57 PM
viktor04g35's Avatar
hey guy i was wondering what is the easiest way to change the headlight bulbs in my 06' coupe??
Old Mar 15, 2009 | 01:04 PM
eurodre's Avatar
jack the car up pull fender liner down near that area, open the cap and pull the bulb out..
Old Mar 15, 2009 | 01:05 PM
Solekeeper's Avatar
Should have searched.
Just loosen the headlight and gain access to the main bulb. It's the one with the dustcap, turn counterclock or something and it untwists.. Then remove, and bulb will be there. Don't touch new bulb with your hands... will blow prematurely.
Old Mar 16, 2009 | 11:57 AM
BostonG6spd's Avatar
You dont have to jack the car up, or even remove the headlights.
Just turn the wheels the opposit way of the side that you are working on, take out the 3 snap in plastic tabs. Unscrew the 2 screws, peel the fender lining back, and you should be able to see the back of the headlight. Turn the dust cap counter clockwise, istal bulb.
Do the same on the other side.
Old Mar 16, 2009 | 03:58 PM
Thnx a lot guys!!
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
itztwinki3
Lights
Oct 15, 2015 04:38 AM
as25656800
Aug 9, 2015 07:25 AM
EasySausage
Jul 20, 2015 03:56 PM
attarday
Jul 15, 2015 04:03 PM
