Changing my entire headlight!
Old May 28, 2009 | 03:02 PM
ConradoR's Avatar
Hey guys,
So after many mods, it's now time to mess with the exterior lights... after a couple of days researching... this is what I came up with:
Changing following on my 04 Coupe, getting it all from Vleds...
City lights and License Plate:
194/168/158 bulbs
http://v-leds.com/Exterior-LED/Parki...11110-1-2.html
Clear corners
6" White LED Strips
http://www.v-leds.com/Interior-LED/D...tml194/168/158 bulb.
headlight's turn signal
Chrome 7443 bulbs that shine amber, but I'll mod it so that it only lights up when I use the turning signal, to prevent the amber color to mess up the white light patern (I'm switching the housing lens to clear....)
clearance strip
12" White LED Strips
http://www.v-leds.com/Interior-LED/D...74229-1-3.html
Could someone who knows their products (LED Mastassss) check to make sure that these will work??
Do you guys think that adding the led strips for the clearances AND clear corners too ricey?? Maybe just Clearance?
Do I need to change any other bulbs to match?
Oh yeah i'm also painting the housing flat black in the processDOMO
I'm gonna wait for replies to make sure I got it all figured out... then I'll get to it, and post pictures after I'm done
Old May 28, 2009 | 03:19 PM
alexcaro's Avatar
for the clearence strip, if your going to open your headlight to paint them, place the led strip inside underneath the clear strip instead of placing them on top.
Old May 28, 2009 | 09:49 PM
ConradoR's Avatar
Thanks alex, I'll make sure to do that once I'm painting the housing
Old Oct 1, 2009 | 11:53 AM
MrMarc's Avatar
Is it possible to insert the LED strip without having to open up the headlight assembly? One of my bulbs just went out, and I had originally planned on replacing them with the LED replacement for the bulb until I stumbled across ConradoR's other post where he posted pics of the headlights. Figured I'd ask the question here because this is where I found the links to the strips he used.
PS: ConradoR, I blippin' LOVE those lights, mang!
Old Oct 4, 2009 | 02:33 PM
ConradoR's Avatar
MrMArc,
I can't think of a way to get in there without separating the whole assembly, since you have to remove the original plastic part of the clearance strip in order to fit the led strip.
Then, to make it look as close to stock as possible, you have to cover the led strip with some kind of flourescent light cover (the sheet of plastic that goes in front of those flourescent tube lights in offices). Got mine from Lowes.
Took me about two days to do the whole assembly, including dremeling the ugly orange turning signals, and fitting ones made from the flourescent light cover. So make sure to have enough time or another car to use it if you need to.
Good luck
Old Oct 4, 2009 | 06:06 PM
MrMarc's Avatar
Thanks ConradoR. I actually plan on doing this first on a set of extra headlights if not to simply practice on first. I am hoping it all goes well and I end up bring able to do a projector retro since I do want to keep the clearance lamp.
Old Oct 12, 2009 | 06:53 AM
SIKHestG35's Avatar
can someone tell me how to remove the lens from the assembly? it has epoxy all around it, and I was wondering the best and easiest way to remove it, since this is my first major DIY project. Thanks for the help.
Old Oct 13, 2009 | 11:24 AM
SIKHestG35's Avatar
do I have to sand the chrome part of the headlight before using the spray paint? Helpful tips much appreciated, I am afraid to mess up the lights.
Old Oct 13, 2009 | 12:36 PM
MrMarc's Avatar
You don't "have" to, but you will want to. You want to prep the surface so it is more receptive of the paint. I suggest you read up a little bit on painting basics, material that covers prep work, how to apply the paint, etc. It's really simple, but you will want to know it before starting...unless you don't really care about the quality of the work you will be doing.
You really should do some research. This information is widely available, including here on this forum. As others will point out to you, "use the search" feature.
Jusseth
Sep 13, 2020 12:25 PM
nineiron
Aug 19, 2015 12:45 AM
RA081024
Aug 18, 2015 07:03 AM
miata007
Aug 17, 2015 04:36 PM
