PROBLEM with my new lights! Help!
Old May 31, 2009 | 09:11 PM
JRollo's Avatar
Angry PROBLEM with my new lights! Help!
ok i just finished installing my new 06 Projectors onto my 04 g coupe. Its canadian so i had to wire in the daytime running lights. we must've f'ed up somewhere because they are acting weird.
- One DRL isn't working, on the same light the high beam won't turn on
-on the other light the only way the high beam will turn off is to switch the lights off or to on manual not auto. It will run on low beam fine until you switch to high beam
any ideas? have to obviously check the DRL wire on the one but not sure about the high beam not turning off problem.
Thanks in advance
chinee
Jun 10, 2024 07:48 PM
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
Lsantana757
Jul 20, 2015 09:08 AM
attarday
Jul 15, 2015 04:03 PM
