Rear lights dont turn on with headlights?
Hey guys i just noticed last night my rear lights are completely out. my brakes and reverse lamp work fine but when i turn on the headlights nothing turns on in the rear. I looked in the manual for rear light fuse but it doesnt show. anyone know how to fix this? thanks John
There a fusebox behind the battery. Well there's actually 3 fuseboxs but the one you need is behind the battery. Find the blow fuse and replace. Happened to me about a year ago. It took 2weeks to find the damn fuse. GL
i looked at those too but maybe didnt look good enough. i will try again. know what fuse it is? thanks john
top left corner...your corners and radio are probably out too, yes?
NO corners and radio work fine. actually i take that back because i havnt checked the corners but the radio is fine. cant find which fuse it is. one post said "behind battery"? im assuming in front of battery right? stilll not sure which one it is. help.
ahh i see. whats the deal with 3 fuse boxes? ill take it off and check thanks danny and everyone else.
yes,top left fusein the fusebox behind the battery,prettysureitis a 10A
That's the same fuse that has blown twice on me over the past week. It is correlated with the starter/ignition circuit. I had no other symptoms other than the car doesn't start.
It's labeled "A/T CONT" (I dunno wtf that's supposed to mean).
I do not think that this fuse is the OP's problem, but if I'm wrong, I'll be confused.
By any chance do u have any LED bulbs in ur signals? Cause i just put a 10a in my 71 and when i hit the lights blew right away. i'll try 15a tomorrow.
Luisgalvan33
Jul 19, 2018 08:16 PM
bTanz
Oct 15, 2015 02:31 PM
