Difference between Philips bulbs
Old Jun 22, 2009 | 09:59 AM
hyunkoon's Avatar
I found this information from forums.maxima.org
Look on the bulb and make sure they are the same bulbs.... They should have the numbers and information on the bulb.
Phillips d2s 85122's = start out yellow but color shift quickest = becomes dull
Phillips d2s 85122+'s = start out yellow and stay yellow = stays bright
Phillips are by far the most popular bulbs. I don't know what brand Nissan sells though.
42402 Philips D4S 4100K 3800lm watts mercury-freely yellowish-warm
42402 V269 Philips D4S 5800K 3300lm mercury-freely snow white
42406 V356-P2 Philips XenEco D4S 4100K 35W P32d-2 3800lm E-permission, mercury-freely yellowish-warm watts
53550 GE D2S Blue 35W P32d-2 5100K 2800lm watts with pink note
53560 GE D2S Superblue 35W P32d-2 10000K 1400lm light blue with Grünstich
53570 GE D2R Blue 35W P32d-3 5100K 2800lm watts with pink note
53580 GE D2R Superblue 35W P32d-3 10000K 1400lm light blue with Grünstich
62301 Osram Xenstar D-HC2S 35W 5400K D2S D-HC high color burner, very neutral white and only lamp without color pass, optically like xenon into the early 90ern as it on the market, is not any longer manufactured, residual item came available (email at author)
62305 Osram Xenarc electronics D-HC1S 35W 5400K D1S best white (unbunt), whiter and more brightly than Ultinon, no yellow or red pass, less red salts in the discharge tube as Ultinon, optically like xenon into the early 90ern than it on the market, is not any longer manufactured, residual item came available (email at author), like 62301 only in D1S Xenarc watts
66040 Osram D2S 4150K 3200lm E-permission halogeneous-yellow Xenarc electronics 35W watts
66042 Osram D1S 4150K 3200lm E-permission halogeneous-yellow Xenarc electronics 35W watts
66043 Osram D1S 4150K 3200lm E-permission halogeneous-yellow Xenarc electronics 35W, new standard type watts
66142 Osram D1S 4150K 3200lm E-permission halogeneous-yellow Xenarc watts
66050 Osram D2R 4150K 3200lm E-permission halogeneous-yellow Xenarc electronics 35W watts
66052 Osram D1R 4150K 3200lm E-permission halogeneous-yellow Xenarc electronics 35W watts
66053 Osram D1R 4150K 3200lm E-permission halogeneous-yellow Xenarc electronics 35W, new standard type watts
66152 Osram D1R 4150K 3200lm E-permission halogeneous-yellow
85122 Philips D2S 4100K 3200lm E-permission yellow-greenish watts
85122+ (plus) Philips D2S under 4000K 3100lm E-permission yellowish watts
85122CM (color match) Philips D2S 5000K 3100lm E-permission snow-white (a little yellow), very near at the Unbuntpunkt, glass bulb has a breath of blue pass, first-class white (more purely than Ultinon) with permission
85122WX Philips D2S 6000K Ultinon 2400lm pure blue-violet without yellow, bluish color like it in former times with some cars looked white
85122YX Philips D2S 3000K yellow xenon light for fog headlights
85122NX 4100K (only Japanese market), similar to 85122, DOT
85122CX 5000K (only Japanese market), similar to 85122CM DOT
85122SX 5700K (only Japanese market), similar to Osram D-HC
85122FS 6700K (only Japanese market), since 2005 blue esters burners of Philips
85123 Philips D2S 4900K E-permission, and +Plus, yellowish watts coloured intermediate thing between Ultinon comparably with pink note (allegedly special for BMW), with GE's Xensation 5100K burner, but yellow as Color matches (85122CM)
85126 like 85122, but D2R with shielding mask for reflector headlights
85126+ like 85122+, but D2R with shielding mask for reflector headlights
85126CM such as 85122CM, but D2R with shielding mask for reflector headlights 85126WX such as 85122WX, but D2R with shielding mask for reflector headlights 85126YX such as 85122YX, but D2R with shielding mask for reflector headlights 85126NX such as 85122NX, but D2R with shielding mask for reflector headlights 85126CX such as 85122CX, but D2R with shielding mask for reflector headlights 85126SX such as 85122SX, but D2R with shielding mask for reflector headlights 85126FS such as 85122FS, but D2R with shielding mask for reflector headlights
85407 Philips D1S, integrated starter, otherwise like 85122 (the ignition equipment makes only the operating voltage available)
85407+ Philips D1S, integrated starter, otherwise like 85122+
85408 Philips D1R, integrated starter, otherwise like 85122
85408+ Philips D1R, integrated starter, otherwise like 85122+
Danielek
Aug 18, 2025 01:33 AM
lil beezy
Lights
Nov 16, 2015 02:52 AM
SupermanGPS
Sep 19, 2015 01:42 PM
twentyeggs
Sep 11, 2015 03:58 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
