Tapping into switched power in the cabin
Old Sep 7, 2009 | 10:40 PM
DiGil's Avatar
Can somebody point me to an easily accessible harness where I can tap into 12V power that switches on with the headlights? If worse comes to worse, I suppose I could tap into the ashtray light.
Old Sep 7, 2009 | 11:15 PM
alexcaro's Avatar
What are you trying to connect? You can tap into the headlights themselfs or the side markers.
Old Sep 7, 2009 | 11:18 PM
DiGil's Avatar
I'm wiring up some ambient lighting. I'd like to stay in the cabin for that.
Old Sep 7, 2009 | 11:33 PM
mesias's Avatar
I believe that the gloves compartment only gets power when the headlights are on. Still, you need to tap before the open/closed switch.
Old Sep 7, 2009 | 11:39 PM
alexcaro's Avatar
Your wiring some interior lights to go on when only your headlights are on? Just get a switch for them and tap into the battery, adding a fuse, that way they are only on when you want.
Old Sep 7, 2009 | 11:45 PM
DiGil's Avatar
They are low level ambient lights. I don't want them switched independently. The glove compartment light seems like a good choice, but I was hoping there would be an easily accessible harness in the fuse box area someone could point me to.
Old Sep 8, 2009 | 12:25 AM
binder's Avatar
there is a blue wire with red stripe down in the left kick panel. It's the positive wire when teh lights are switched on. You need a 12v test light to check it though because there are a couple that are that color.
I'll have to get a picture of my setup. I had to use that for the dimming of my gauges.
Old Sep 8, 2009 | 12:49 AM
DiGil's Avatar
Thanks binder. That's just what I'm looking for, I'll have to check it out.
Old Sep 9, 2009 | 01:08 PM
binder's Avatar
crap, i forgot about this. hmm....i'll try to get that picture up tonight.
I don't remember if i found the wire from a suggestion on here or my350z. search for "gauge dimmer" or something like that and you might find it before i get the picture up tonight.
Old Sep 13, 2009 | 05:59 PM
akw's Avatar
akw
parklight wire red/blue
Old Sep 13, 2009 | 08:58 PM
binder's Avatar
that would be it. There are a few in there so make sure you use a test light to check which one is +12v when the lights are switched on.
Old Sep 15, 2009 | 12:14 AM
akw's Avatar
akw
use a computer safe test light, grounding test lights can cause damage if poking the wrong wire. The safest way to test wires is still with a digital multi meter
Old Sep 21, 2009 | 11:19 AM
DiGil's Avatar
Thanks for the pic akw, I'll be checking this out with a multimeter. I'll post pics in a couple weeks when I have some nice unique ambient lighting to show off.
jilljann1
Jul 21, 2020 08:12 AM
mattdg35
Sep 14, 2015 11:28 AM
AuAltima3.5
Audio/Video/Electronics
Sep 13, 2015 11:48 AM
G35VSHNG37
Sep 10, 2015 01:54 PM
zcherub
Sep 10, 2015 12:03 PM
