Started my Quad Project
Old Dec 3, 2009 | 12:50 AM
cc_brandon's Avatar
So I've been slowly but surely gathering parts to start my quad project. I just ordered the rest of the parts which I'll have next Wednesday. I wanted to try and keep the OEM look so I went with G35 projectors. I ended up finding a set of 06 headlights that I could use for parts so I picked that up.
The housing, bezel, and lens are damaged on one but I can still use the projectors and shrouds from both.
I'll be using the following parts:
-G35 projectors
-G35 shrouds
-Matsu****a Gen 3 Ballasts
-TSX-R Clear Lenses
-Philips 85122+ Bulbs
The plan is to wire it so that it will have quad hi and low beams. I'm planning on just tapping into the solenoid wires on the OEM projector. I'm assuming this should work fine? I may or may not do DRL's, haven't decided yet.
I've also begun working on mounting a projector lens into the turn signal housing. Pretty straight forward to do so far. Here's a quick pic of the mock-up.
Update coming soon
Old Dec 3, 2009 | 05:47 AM
VictoriousG's Avatar
Sounds sickk
Old Dec 3, 2009 | 08:28 PM
Beebo's Avatar
wish i knew how to do this stuff... good luck
Old Dec 3, 2009 | 08:30 PM
Locksmith's Avatar
Good luck man keep us posted with pix
Old Dec 11, 2009 | 01:26 PM
cc_brandon's Avatar
Most of the stuff came in, just waiting on the bulbs and LED's now. I also finished fitting the projector lens into the 2nd turn signal.
Another thing I just decided to do was make my highbeams open my garage door. I'm pretty much done that, just have to wire up the relay and put it in the car. I might just do it when I swap my headlights.
Old Dec 11, 2009 | 01:56 PM
Locksmith's Avatar
Looks great man! What type of projector lens did you use for the turn signals?
Old Dec 11, 2009 | 02:47 PM
cc_brandon's Avatar
Thanks! I'm not exactly sure what kind it is. Matt from the Retrofit Source had them laying around and threw them in with my other stuff. I think the main thing is that it is the right size. I'll measure the lens if you want
Old Dec 11, 2009 | 07:41 PM
Frankieg35's Avatar
How are your highbeams gonna open your garage door?? Thats sick!!
Old Dec 11, 2009 | 10:47 PM
accordfreak's Avatar
is your driver side housing lens damaged? if not, may I buy it off of you?
Old Dec 12, 2009 | 02:04 AM
cc_brandon's Avatar
It's actually pretty simple, assuming it works lol. If it does, I'll probably post up a DIY on it. More or less, you just solder wires to the button on the garage door opener, wire up a relay to trigger the button when the highbeams are turned on, and it should send a open or close signal.
The chrome bezel or the back black housing? If it's the black housing, you're in luck. That's really only the extra part I think I'll have though. If that's what you need, send me a PM
Old Dec 13, 2009 | 04:59 PM
WOW open the garage door huh I've never heard of such a mod,but what happens when you sell the headlights couldn't someone open your garage door then? whatever the case those are awesome headlights
Old Dec 13, 2009 | 07:02 PM
davidxu's Avatar
since the relay to send the signal to open/close the door would be connected to the high beam switch, and not the headlights, i would assume no matter what head lights are in, the switch would still work
Old Dec 14, 2009 | 01:08 AM
cc_brandon's Avatar
Yup, I'm planning on tapping in the wires at the IPDM. So if I ever do sell the headlights, my opener and relay will still be in the car. I was originally planning on tapping into wires at the headlights but I was worried about water getting at it. Tapping at the IPDM will give it protection from the battery cover so I figured that was my best bet. You could also probably do it near the BCM.
New update and pics tomorrow, maybe a DIY for the garage door opener too
Old Dec 14, 2009 | 06:36 AM
Tiiiiiiight setup DIY ftw
Old Dec 14, 2009 | 09:58 AM
Andrei's Avatar
That is a really good setup.
If you can do that post a DIY.
