bulb upgrade need link help
Old Dec 15, 2009 | 09:30 PM
3rick35c's Avatar
Under Construction
Exclamation bulb upgrade need link help
while I was deployed I decided to upgrade the 04 headlamps to 06-07 headlamps. but I had a local shop do the install. I recently decided to upgrade the HID blub to a higher temp in addition to this upgrade the fog to HID. I been trying to search for a DIY or Tech link for the blub and HID swap but could not find anything... can someone throw a link up for me???... thanks!
Old Dec 16, 2009 | 07:34 AM
psedog's Avatar
Back in SD**
To change the HID bulb you are going to have to pull your fender liners out to gain access. The rest is self explanatory. Honestly it is easier to lift the front of the car and pull off the front wheels. If you don't want to lift it, then turn your wheel one way. Remove that fender liner and change the bulb. Repeat the process for the other side.
If I was still in SD I'd help you out. Check with Ryan, Jay, or Shawn. They are pretty helpful
Old Dec 16, 2009 | 10:12 AM
Marinelli Motorsports's Avatar
Here are a couple:
https://g35driver.com/forums/body-in...hid-bulbs.html
https://g35driver.com/forums/body-in...og-lights.html
If you havent gotten any bulbs yet let me know and I will work you a good deal
Old Dec 16, 2009 | 11:15 AM
3rick35c's Avatar
Under Construction
thanks alot fellas
Danielek
Aug 18, 2025 01:33 AM
lil beezy
Lights
Nov 16, 2015 02:52 AM
twentyeggs
Sep 11, 2015 03:58 PM
johnadlertech
Lights
Sep 4, 2015 12:35 PM
