Clear Corners
Old Aug 30, 2004 | 10:40 PM
dek1's Avatar
Clear Corners
Help.....
I'm new at this and was hoping somebody could lay out (step by step) on how to remove current corners and install clear corners.....thanks.
Old Aug 31, 2004 | 07:42 AM
GR8TG35's Avatar
Re: Clear Corners
It will show you in the back of your owners manuals under the lighting section....
It takes little or no effort to remove the lense assembly.....
Either wrap a flat head screw driver in a rag, and insert it between the wheel well side of the marker and gently push it out....it should pop right off, disconnect the bulb socket by turning a 1/4 - 1/2 turn, and replace it the same way on the clear corner....
Put it back in by putting in the front part first and then push in the back section and your done.........
Many here just pull it off with their hands......which ever works for you.....but its really easy.....
04 cpe IP/willow/5at/prem/18's/JDM clear corners/Piaa's/MTEC H4 Super White fog/highs
Old Aug 31, 2004 | 12:26 PM
JAMNG35's Avatar
Re: Clear Corners
Good instructions there. I just did the mod myself this past weekend. Took me about 10 mins total (cuz i was going slow). SUPER easy..
2004 5AT Brilliant Silver - Premium - Rollin Stock with many mods to come! 510 Miles and counting...
Old Sep 1, 2004 | 12:03 AM
skeleton_cru's Avatar
Sedan
Re: Clear Corners
Hey dek1, try the search function before you post. You'll get most of your answers much quicker.
Marlin84
Apr 1, 2020 12:52 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
