Flickering Left HID Headlight
Old Feb 23, 2010 | 09:09 PM
VinhFTW's Avatar
Hey guys, I switched my headlight bulbs because my right headlight went out, but the bulb wasn't the problem. I found out some water got into my ballast. I let it drip out and let it sit in the sun. Then it started working again.
I painted my headlights flat black with gloss and when I hooked it back up, my left headlight wasn't working anymore. It flickers when I try to turn it on. Before I painted my headlight, my left light was working perfectly.
I tried checking if all the cables were plugged tightly 3 times, but still nothing.
Any ideas?
Old Feb 23, 2010 | 09:22 PM
A_J's Avatar
A_J
same here, light flickers a little to come one but doesn't turn on.
Old Feb 24, 2010 | 01:46 PM
VinhFTW's Avatar
i'd figure a flickering headlight should be a pretty common issue
Old Feb 25, 2010 | 05:32 PM
VinhFTW's Avatar
bumpp
Old Feb 26, 2010 | 10:36 PM
VinhFTW's Avatar
nobody knows how to fix a flickering a flickering headlight?
Old Feb 28, 2010 | 12:17 AM
Dacket84's Avatar
IIRC Flickering HID bulbs is a pretty good sign that they need to be replaced...
Old Feb 28, 2010 | 07:23 PM
VinhFTW's Avatar
I just bought them about a week and a half ago though...
Old Mar 1, 2010 | 01:47 AM
UltraBlue600RR's Avatar
when the HID's flicker and don't turn on they are blown. If you just purchased them, they should come with a warranty. Most common is 1 year. There are HID bulbs on Ebay now that have a lifetime warranty.
Old Mar 1, 2010 | 01:59 AM
Adon's Avatar
you probably bought bad bulbs, check all your fuses, I was doing custom work on my headlights as well one time, and accidentally blew a few fuses which resulted in my headlights acting weird and also my taillights and interior lights not working.
The culprit in my case was bad bulbs which drew different wattage than the OEM, thus causing a short and blowing a few fuses.
There are 3 fuse boxes to look for, one right next to the clutch or brake, one next to the battery, and the last one is tricky, it's hidden above the battery in a closed hard to find compartment.
Old Mar 1, 2010 | 12:01 PM
GAU-8's Avatar
Do they flicker with the car running or off? If you're flickering while running, it's possibly a bad bulb. If it's flickering on battery only, you could have a weak battery not supplying enough voltage to keep the ballast ignited.
Old Mar 2, 2010 | 01:28 PM
VinhFTW's Avatar
both, it flickers while the car is on or off. I'll change to my OEM bulbs, if it still works i'll hit up the guy I bought it from.
Old Mar 2, 2010 | 02:15 PM
IrockAG35's Avatar
Ohio G Club moderator
ive had a fair amout of ecperience with g hls, im going to guess and say its your ballast,if the right had water in it whose to say the left ddint get wet as well. easy way to fix a ballast thats been exposed to moisture is this: get a sandwich bag(ziplock brand) get plain white rice,place ballast in bag,then cover ballast with the rice. ensure the ballast is completely covered,then make sure all the air is out of the bag...let the ballast sit in there for about 2 days..or as long as possible. id do this to both of them
the rice removes ALL moisture,sounds ghey but this will work,also works on cell phones
Old Mar 2, 2010 | 02:16 PM
IrockAG35's Avatar
could also be your ignitor,ive got a few extras. if u need one pm me ill sell u one cheap.
Old Mar 2, 2010 | 02:20 PM
WILLIE BEANS's Avatar
my bulb would flicker then stay on . for a fe months . till it just didnt come on ..
i changed bulb but it wasnt that ..so i changed the ballast and thats what was wrong ..
the ballast was going till it was gone ..
Old Mar 2, 2010 | 04:41 PM
Adon's Avatar
ah the item in a bag or bucket of rice trick, that works very VERY well... it worked wonders for my iPhone, got all the water out completely, good tip iRock
