Question about Quad Projector retrofit
Old Jul 21, 2010 | 11:25 AM
mr_luv's Avatar
My Quad Projector retrofit
Well I am one lamp down on my Quad setup, Low Beams are going to be RX330ASF clear lens, Fogs Are going to be FX with clear lens.
Heres my info from a thread I piggy backed decided I needed a thread of my own.
And its time to getterdone!!!
I went with the ebay JDM blacks.
These: http://cgi.ebay.com/ebaymotors/ws/eB...d=435004882003
They seemed like the best (JDM) LOL black housings on ebay. And the best discription.
Projectors are going to be FX projectors had them for years way back when they had the FX recall and the market was flooded with them mated with Purple coated clear lens from JDM ( Love how that word is thrown in the title) Junk mustang projectors scored from my sis' n laws failed attempt at clearing her lamps hacked and melted lamps.
Shrouds are going to be theretrofitsource Gatling Gun shrouds.
http://www.theretrofitsource.com/pro...56d3b1dbcb50ef
Bulbs & Ballast are gonna be Toyota/Lexus D4S 4100K reason I am going with these vice 5K 6K I rather my lens and projector give me my color and cut off instead of the bulbs my personal preference.
The FX and Gattling gun Shrouds will be on the bottom, The RX and IS250 Shrouds will be up top, I will post some pix tonight all the trimming and measuring is done on one lamp just need to aim and mount. After that comes the clean up and install.... Which me luck.
On to the pix:
Now that all the trimming is done, I need to aim and drill mounting holes and start on housing number 2. Final aiming will be done on the car seal up leak test and roll out!!!!!
Went back to the RX330 ASF, just fit better up top. And didnt see the point going quad Bixenon. Here is a quick oncoming flicker vid, will post cut offs later.
Cutoff Pix taken with Iphone, 15-20 feet away.
Driver Passenger:
Driver:
Passenger:
Driver Passenger:
Old Jul 27, 2010 | 01:25 AM
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
You'll need a H4 harness that will allow you to keep the "low beam" on (the fog light) when the high beam is triggered. On the stock lights, if you have the fog light on, the high beam filament of the H4 bulb is off. And vice versa. Without the harness, if you hook this up to a bixenon projector, you'll just get the shield moving when you flip on the high beam, but no actual light output.
Old Jul 28, 2010 | 11:28 AM
mr_luv's Avatar
Thanks, I figured it out after lots of searching and some research...
Old Jul 29, 2010 | 09:56 PM
mr_luv's Avatar
Pix added!!! Tell me what you think.
Old Aug 25, 2010 | 12:57 AM
JZeezG35's Avatar
I wont lie. its a nice job. and with more practice and the right tools, (assuming you dont already have them). It has lots of potential. I would maybe go with different shroud selection to help shape the inside of the headlight around the projectors and form a cleaner seam with the surrounding housings, and some symmetry between the two projectors. I'm actually a full time professional Retro-fitter and Automotive Lighting specialist, in addition to a DIY Modder. I rarely allow anyone to do work on my car. In the rare cases, Its only if I dont have access to the proper tools needed for the job at hand. I would love to do a retro-fit for you. You know how to get in touch with me.
Jay
Old Aug 25, 2010 | 10:04 AM
the04coupe's Avatar
keep the pics coming . Its gonna be hard to fit those gatling gun shrouds good . I ordered them once for a retro not realising how huge they are . If you cant fit them a good option is the g35 sedan shrouds
Old Aug 26, 2010 | 07:50 PM
mr_luv's Avatar
Whoa I was sure you were a dick, guess I was wrong, thanks for the encouragement I already got the shrouds figured out they wont be a issue.
To address the seams and lines of the cut outs I will just paint the reflectors black. Hey can you send me some pix of your work I would love to see them and get more ideas, I spend hrs of my work day watching DIY's on youtube and searching to get ideas and know how. I def dont have the right tools, a drimmel and a drill I am still learning.
Jay
The shrouds wont be that big of a issue already got a plan to do them, I wish I had some G shrouds they would be perfect.
Old Sep 29, 2010 | 12:05 PM
mr_luv's Avatar
Updated content. Almost done.
Old Sep 29, 2010 | 04:47 PM
visibiliti's Avatar
Cool project. Excited to see them sealed and installed on your sedan.
Old Feb 17, 2011 | 05:10 PM
JZeezG35's Avatar
I wanna see these on the car. updates?
Jusseth
Sep 13, 2020 12:25 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
