Strange issue with LED interior lights
Old Sep 11, 2010 | 11:00 PM
Nap's Avatar
Nap
08 35X
Replaced all the interior lights with LED's.
When I'm in my pitch black garage I can see one of the dome/map lights and both door lights stay dimly lit when they should be completely dark.
If I turn the dome light switch to "off", the dome led goes completely dark. When the switch is set to turn on when the door opens the LED never completely shuts off.
Anyone else have this behavior? its like the leds are still getting a tiny amount of current when the should be off.
Old Sep 12, 2010 | 09:52 AM
Marinelli Motorsports's Avatar
If you do a quick search you will see alot of ppl have this problem.
It's perfectly normal.
Old Sep 12, 2010 | 06:36 PM
djfarhan's Avatar
what color did u switch them to?
Old Sep 12, 2010 | 11:01 PM
sTeadFasT96's Avatar
As what M-Motorsports said. That is a completely normal behavior. If I'm correct, it is because it does not take much power at all to get them lit even so slightly even if they really "shouldn't" be lit at all. No worries though, your battery won't be drained or anything.
Old Sep 13, 2010 | 11:45 PM
Nap's Avatar
Nap
just white
Old Sep 13, 2010 | 11:50 PM
Nap's Avatar
Nap
ahhh so the stock bulbs prob had some current going thru them also but not enough to make visible light. Interesting. leds are more sensitive so that's why the fading affect doesnt occur with leds either i get it now
Old Sep 13, 2010 | 11:51 PM
O HELLA OEM's Avatar
ITS NORMAL, same thing happens to me
Old Sep 13, 2010 | 11:57 PM
dukehotty's Avatar
Mine do the same thing.
Old Sep 14, 2010 | 12:22 AM
djfarhan's Avatar
Originally Posted by Nap
just white
1st mod! ;-P
Old Sep 18, 2010 | 05:47 AM
edimean22's Avatar
how do you change out the stock to the leds. how do you take off those covers on the celieng to get to the bulb on a 04 sedan?
Old Sep 18, 2010 | 02:24 PM
djfarhan's Avatar
use a flat screwdriver (cover the tip with a cloth) and then wedge it on each side and slowly take it out.
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
JMSABO
Aug 4, 2015 11:58 AM
newg37
Jul 26, 2015 09:32 AM
Jadenkid22
Jul 14, 2015 12:33 AM
