DIY: 05/06 Tail light swap
Old Sep 17, 2010 | 04:13 PM
Rodrigo's Avatar
I managed to pick up a set of 05-06 G35 sedan tail lights to swap into my 03.5 sedan . figured i would do a small DIY write up to help those who would like to do this in the future.
its very easy i would say a dificulty level of 2 on a 10 scale. depending on your abilities this install should take between 15 min to 1 hour.
I searched for about 6 months before finding a good set and not paying an arm and leg.
price ranges from $150-$300 used
New MSRP $265 - $198.00 each from infinitiparts.com
http://www.infinitipartsusa.com/part...layCatalogid=0
TOOLS
8mm socket
socket wrench
flat head screw dirver
step 1. open your trunk , if you have a cargo net unhook all 4 hooks and set aside.
step 2. withe the screw driver pop open the 4 plastic anchors and set aside.
also remove the 2 center anchors and 2 outter ones
step 3. pop open the plastic trunk piece by pulling towards you , make sure all anchors have been removed before doing this.
Old Sep 17, 2010 | 04:16 PM
ttrank's Avatar
Grocery getter
You have the same two pictures over and over.
thescreensavers's Avatar
Mr.202?
did you cut the safety bolt?
Old Sep 17, 2010 | 04:26 PM
ttrank's Avatar
Grocery getter
Ah, pics are better now.
Might want to add pics of the tail light nuts you remove.
Old Sep 17, 2010 | 04:32 PM
Rodrigo's Avatar
step 4. lightly pull the trunk liner away from the rear of the light ,
once you expose the back of the lights you will see the 4 screws that hold the light locked in place. with the socket wrench just loosen all 4 and then unscrew by hand.
the screw furthest from you will have the harness attached to it just pull it out gently and let it hang until its reassembling time.
once you unscrew all bolts and have removed them , unplug the light and gently push the light out from the inside carfully to break anything. repeat on the other side.
step 5 . once you remove both lights out take advantage and clean the are , you will see alot of crud and or dirt , i used a spray bottle and rag and cleaned it all .
Old Sep 17, 2010 | 04:33 PM
Rodrigo's Avatar
im doing it as your reading this , patience Tim , lol
Old Sep 17, 2010 | 04:34 PM
ttrank's Avatar
Grocery getter
LOL
Sorry.
I'll move this to the DIY once you're done.
Old Sep 17, 2010 | 04:41 PM
Rodrigo's Avatar
Step 6. once its all cleaned install the new lights
plug in the back and guide the light in place , hand tighten nuts and then with the wrench 1 and a half turn. re attach the harness to the last nut . Plug the light to harness.
repeat on the other side .
step 7. reassemble the trunk pieces . rehook net and close the trunk
enjoy your new lights
Mr.202?
How did you remove
When my light fell out when I was polishing it, thats the only thing that saved it but I could not re tighten the bolt behind it
Old Sep 17, 2010 | 04:45 PM
Rodrigo's Avatar
the bolt is under it , its hooked on by the thread
Old Sep 17, 2010 | 04:47 PM
Mr.202?
^ I am talking about the plastic part.
Old Sep 17, 2010 | 04:51 PM
Rodrigo's Avatar
yes , the nut goes on first tighten that then push the plastic in with light pressure the plastic piece will be attached by thread of the bolt
Old Sep 17, 2010 | 07:05 PM
Blue Dream's Avatar
I drove ttrank's car solo
Good stuff and a definite upgrade for the 03-04 sedans. Now if you could just replace your interior that easy..........
Old Sep 18, 2010 | 04:34 PM
Rodrigo's Avatar
thanks , i have a set of coupe seats that if i dont end up selling them i might just drop them in.
problem is i bought them a few weeks before i lost my job so i think trying to get the cash i put on them back .
$500 , shipping is way too expensive
Old Sep 18, 2010 | 11:08 PM
heph's Avatar
Thanks for the DIY. It looks very straightforward except for finding 05/06 tails at a reasonable price!
I would gladly take the coupe seats off your hands if I didn't live on the other side of the country.
