Interior light removal help!
Old May 24, 2011 | 12:04 AM
ryanm8's Avatar
Anyone have any tips on removing the side lights above the rear windows of the sedans (not sure if they are in the coupes as well)? I can seem to pry off 3 sides of the lens and can see the bulb inside, but the 4th side seems to be held in by a screw. I have not been able to remove the whole housing either.
Old Jun 4, 2011 | 07:33 PM
Eye Eat Ketchup's Avatar
for mine, i had the same issue. I removed the whole housing (there were two metal clips located at the top and bottom). I pulled up first, to dis-engage the lower metal clip, then I shimmied down, to dis-engage the upper metal clip. The housing then came off and I saw the little metal screw behind the switch. After I removed the screw, I was able to pop off the lens with a screw driver.
I can post pictures up later if needed. I'm no expert though, but it worked for me
Old Jun 5, 2011 | 06:14 PM
ryanm8's Avatar
Thanks man. I actually figured it out and finished doing the install yesterday. Looks nice now, I have all my lights replaced with LED's
mike730
Jan 12, 2018 04:25 PM
mjfenix
Aug 17, 2017 05:49 AM
rsingerG35
Interior
Aug 13, 2015 05:01 PM
Jadenkid22
Jul 14, 2015 12:33 AM
