Clearance Light Problem
Old Jun 9, 2011 | 09:50 PM
Middleeastg's Avatar
So i have an issue. My clearance lights all of a sudden went out. The turn signal still works but when I twist the **** to vanity mode, nothing turns on. I did replace my clearance light with ccfls, but those have been working fine for 3 years now. And both of them went out at the same time. Not just one. I'm thinking perhaps a fuse? If so which fuse? Any other ideas would be appreciated!
Thanks guys!
Old Jun 10, 2011 | 09:16 PM
Update:
forgot to mention that the dimmer for the dash doesn't work either. it's constantly on full blast....
is there ANYBODY with suggestions???
Old Jun 12, 2011 | 10:05 PM
Okay to add to the problem, just noticed the center console audio lights are not working either. The station illuminates at full blast, but the CD, Radio, PTY/CAT, DISP, Volume, Seek, Tune, Clock, ect ect, are all not illuminated while the rest are lit up at full blast
I'm gonna keep up with this until somebody answers
So far i've tried all the fuses inside the the car, i did another search to find any more answers and found out there are more fuses by the battery.
Old Jun 12, 2011 | 10:07 PM
Old Jun 12, 2011 | 11:06 PM
ALRIGHTY!!! i figured it out! there's a 3rd fuse box!
Old Jun 15, 2011 | 04:03 AM
TRplayboy88's Avatar
I have the same problem...I'm trying to figure out what's thr problem with all the lights goin out....I checked all da fuses under the hood and under the steering wheel...do you know where the othe box is??
Old Jun 16, 2011 | 11:37 PM
THERE"S A THIRD FUSE BOX!!!!!!! you're gonna have to take the flexible plastic cover off by the battery. You're battery cover fits in this peice. Then you'll find a hard plastic box behind the battery underneath the plastic cover you just removed. Pull the tabs at the base of the box and pull up and voila! all your fuses. You replace the top left one with an identical fuse.
Old Jun 17, 2011 | 04:26 AM
LEDmarkers's Avatar
10a tail fuse ^^
mike730
Jan 12, 2018 04:25 PM
wonderizm
Sep 24, 2015 03:09 AM
Lsantana757
Jul 20, 2015 09:08 AM
Ashton35
Jul 17, 2015 10:11 AM
attarday
Jul 15, 2015 04:03 PM
