looking for PIAA LED to match 6000K HID
Old Dec 6, 2004 | 02:51 AM
imRACERX's Avatar
anyone know if theres such a ything? i know of the BLUE PIAAS and the BLUE/WHITE PIAAS. But do they make a say, PURPLE/WHITE PIAAS im LEDS?
im looking to replace my side markers and clearance strip with them but i want them to resemble the 6000k that i just replaced stock with. thanks if not which should i go with? thanks again. RX
Old Dec 6, 2004 | 11:12 AM
afr0puff's Avatar
Supa Dupa Moderator
The regular Piaa Extreme white bulb does end up with a purpleish hue to it. But I'm not sure if the white light output matches 6000k.
What about the piaa white/white LED? That has a noticeable higher kelvin rating when compared to the HIDs, so that might give you the 6000k look. But those end up trailing to a blueish hue towards the bottom of the strip. You may want to check for a new piaa japanese LED bulb which is supposed to be brighter.
Old Dec 8, 2004 | 12:22 AM
6969g35's Avatar
From: FROM BROOKLKN NEW YORK NOW LIVE IN VALENCIA CA.
I got 6000k hids purple/white
match with gtx piaa fogs purple/blueish white
side and clearance piaa white leds
good match
Old Dec 8, 2004 | 02:17 AM
g35thanh's Avatar
the piaa white/white in the clearance matches the 6000k, but it looks different in the side marker. i had to buy a 4led superwhite bulb from ebay for the side markers to match my philips 6000k
Old Dec 10, 2004 | 06:45 PM
imRACERX's Avatar
hey thanks for the reply do you have a web site?
Old Dec 10, 2004 | 06:56 PM
imRACERX's Avatar
are the bulbs the same fit for both clearance and side marker? meaning are they both the 168? thanks RX
Old Dec 10, 2004 | 07:05 PM
Redstradic's Avatar
i myself do not prefer the PIAA. i used polargs in all my lighting. the M-4s are for the side and clearance.
Old Feb 27, 2005 | 04:17 AM
imRACERX's Avatar
hey all, anyone else know what might match my 6000k headlight bulbs? need them for markers, clearance strip, license plate etc etc. the 6000k's have that puple look to them. thanks RX
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
lil beezy
Lights
Nov 16, 2015 02:52 AM
Gabe83714
Oct 6, 2015 06:40 AM
twentyeggs
Sep 11, 2015 03:58 PM
