Extreme White Lighting
Old Dec 11, 2004 | 06:53 PM
ensig's Avatar
Lightbulb Extreme White Lighting
I've finally nailed down the electronics for the Luxeon (xtreme white). For those who previously expressed interest.
https://g35driver.com/forums/lighting/37370-modded-dome-map-light.html=== Original Thread on Luxeon Lighting ===
=== LED Benefits ===
- Increased efficiency and lowered power consumption. (3W vs 10W)
- Increased brightness (80 lumens of directional lighting vs 50 lumens of scattered lights)
You loose 60% of the light for lighting up the top housing when using halogens.
- Pure WHITE! Not even Xenon/HID is this white.
- Lifetime reliability baby! (10000+ hrs before light output decrease to less than 70%)
Here's the package that I offer for those who need more than what PIAAs gives. If you're interested please post here and send me a PM.
=== Package #1 - Map/Dome TurnKey ($90) ===
Description: complete assembly for G35 Coupe or Sedan front Dome/Map lights
- 2x current regulated circuits (700mA)
- 2x Luxeon III LEDs
- 2x custom aluminum heat sink
- 2x modified bulb plugins
- assembled and tested
=== Package #2 - Rear Lights TurnKey ($90) ===
Description: complete assembly for G35 Sedan rear lights
=== Package #3 - DYI Kit ($35) ===
Description: Do-It-Yourself Kit
- 1x current regulated circuits (350/700 mA)
- 1x Luxeon III LEDs
=== Package #4 - Poor Man's DYI Kit ($20) ===
Description: Cheapest Do-It-Yourself Kit
- 1x voltage regulated circuits (<380 mA)
*** LED upgrade package ($7/light) ***
- 20% more lights
All pricing includes US domestic shipping. International will be several $5 more thru USPS GPA
Side Note: I can no longer login as "ensig35" since the forum update.
I lost all previous PMs of individuals who expressed interests Please send a new PM to "ensig"
Old Dec 12, 2004 | 01:52 AM
SI_G35Coupe's Avatar
i was one of the original interested, and i still am. will get back to you shortly about this.
Old Dec 14, 2004 | 12:44 AM
Sukairain's Avatar
Is there any way to fit these Luxeons into the clearance stripe? Is there a minimum size for the aluminum heat sink?
Old Dec 14, 2004 | 11:58 AM
ensig's Avatar
It depends on how hard you drive the light.
For the rear seats I'm using a 1"x2" (2cm x 4cm) heat sink for driving it to 380mA.
You could easily fabricate a one for the clearance light. The luxeon itself will fit inside the bulb socket.
Old Dec 16, 2004 | 02:23 PM
fluffydot's Avatar
Unhappy
Would you consider making something for the Door Step lights as well?
and maybe trunk, thou that is a really small space.
$90 is kinda steep for this kinda upgrade thou....
Old Dec 16, 2004 | 10:20 PM
ensig's Avatar
I'm currently working on the Door Step light and Trunk light, they should be a lot cheaper.
The door step will be using ultra-bright 5mm LEDs which should run < $20/door. While the trunk will be using 3x luxeon with a constant voltage regulator for < $50.
Here the price breakdown of the cost for me.
$22 - constant current regulator
$03 - constant voltage regulator
$10 - Luxeon III LED
$17 - Premium Luxeon III LED
The $$$ I make is on package #1 & #2 which are $20 for assembly, testing & liability ...
You could purchase these directly from Lumineds, Digikey, and Newark if you prefer. It should come out to the same $$$.
Frostbite91
Aug 20, 2015 07:20 PM
julian.dion
Jul 29, 2015 09:16 AM
