06 Instrument Cluster Help!
Old Jan 13, 2012 | 12:43 PM
tucker305's Avatar
2006 Inifiniti G35 Coupe 6MT
Instrument Cluster background lights not working.
All lights on the panel work (battery, door, ABS, brake, VDC, oil, etc..) except for the background illumination i.e. the numbers and bezel around the tachometer and speedometer, fuel and temperature gauges and mileage display.
Click link to view picture
http://imageshack.us/photo/my-images/715/img0259qx.jpg/
Work was recently done to the radio which I believe may have caused the problem. The air condition, clock/dual temperature display works fine, dimming **** also. All fuses checked out good.
Does anyone know a direct method to troubleshoot and fix this minor problem?
Old Jan 21, 2012 | 01:09 PM
TunerMax's Avatar
G35
Definately a power feed issue. Did you check the fuses under the hood as well or just in the car? This sounds like a blown fuse to me man, especially if someone was digging at the Audio unit recently.
Old Jan 21, 2012 | 04:46 PM
2K6G35c's Avatar
Exact same problem here, the only difference is, not a single electrical problem going on with anything else. BTW, either the outside, or the tachometer lights work. Not both.
G35xdriver04
Nov 7, 2015 08:31 PM
wow600rr
Sep 28, 2015 11:50 AM
itgogitrev
Sep 23, 2015 07:08 PM
Blindside360
Sep 18, 2015 09:00 PM
Felipe Gonzalez
Aug 16, 2015 10:02 AM
