Issue with hid conversion for fogs on 06-07 projectors
As the title says, I encountered a problem and just can't seem to find a solution, searched everywhere but couldn't find anything helpful to my particular situation, hope some of you might chime in.
So I bought a cheapo hid kit from ddmtuning to convert the stock fogs to hid. I have 06-07 U.S. spec projectors that I swapped onto my 04 Canadian g coupe. The projectors themselves work fine, but the fogs do not turn on whatsoever. I realise this might have something to do with the U.S. lights on Canadian car, but I have a friend who did the same setup on his 05 and everything works fine. I can't seem to isolate where the issue is coming from. We did the install together so slim chances of the issue being caused by improper installation. Any help/advice is welcomed! Thanks.
Here are a few pics of install process:
Is the end of the black wire connected to the backside of the lamp assembly still?
I had the same problem when I first installed the hid fogs. I guess I pulled the black wire to hard & it unattached from the headlight.
So why don't ypu get the one we did on my car? no cutting plug and play and they were 50 bucks!!!
