View Poll Results: Which film is best
Bluebat
0%
Lamin-X
100.00%
Clearbra
0%
Voters: 1. You may not vote on this poll
Best way to protect headlights
Old Mar 6, 2012 | 12:59 PM
DVG's Avatar
DVG
I am looking to protect my headlights. I have been considering bluebat overlays, lamin-x, and a clearbra.
I need some protection because my headlights have gotten to a point where I will dehaze and wax them, then 2 weeks later they are foggy and oxidized again.
I also need to make sure they wont crack the headlights, it would be preferable if the manufacturer made a guarantee to this effect.
Old Mar 6, 2012 | 01:28 PM
Adro's Avatar
In essense, all of these materials are the same. Just a transparent, vinyl cover for paint/plastics. I'd be willing to bet that bluebat and laminX are the same If they use quality 3M material. It doesnt really make a difference as they would all protect ~the same.
Old Mar 6, 2012 | 01:57 PM
muyrec's Avatar
your're not sealing them after waxing? i use a combination of this http://3mcollision.com/products/buff...rnuba-wax.html and this sealant http://www.wolfgangcarcare.com/plast...e-sealant.html its a water sealant. Protects your headlights up to 3 months depending on driving conditions. It's pretty expensive but i still have my bottle after a year of use. Don't have to use that much. So far the headlights are doing great. But since your headlights are getting hazed in such a short time, you may have a failure on the lens. i had to change out the right side on my 07 G35 sedan because it had the same symptons as you are having. only it would haze up in a day or two.
Old Mar 6, 2012 | 05:43 PM
TunerMax's Avatar
G35
You need to seal them bro! Clearcoat/sealer, etc.
Old Mar 6, 2012 | 07:40 PM
kristof's Avatar
Thanks for the link to the sealant. I need to polish my 07 sedans headlights and seal them. They are starting to yellow at the top :-/
Old Mar 7, 2012 | 12:31 PM
DVG's Avatar
DVG
I didn't know I could reseal them, thats all I have to do? would it be better to reseal them and then put a clear bra over that?
Old Mar 8, 2012 | 12:10 AM
muyrec's Avatar
i would try sealing them first. if it still does it clear bra it then.
Old Mar 8, 2012 | 07:10 PM
DVG's Avatar
DVG
Allright, so I am also taking the tint off of my taillights (sanding it off) this summer, and replacing it with a vinyl tint. I am going to do it the same way I would restore a headlight.
Should I use this sealer on the taillights as well?
The car is also going in for paint, which is better? A Clearcoat, or this sealer?
Is there any problem with putting a clearbra over the headlights after putting that sealer/paint on them (The sealer that muyrec mentioned.)
Old Mar 8, 2012 | 08:33 PM
TunerMax's Avatar
G35
The sealer is basically just a clearcoat anyways. It's just more designed for plastic (apparently)
A professional clearcoat would far surpass the headlight 'sealer' product. Go for it.
Because it's just a clearcoat, yes, you can put a vinyl/clear 3M strip over them afterwards with no ill effects. Just make sure it's nice and dry/hardened.
Old Mar 12, 2012 | 08:18 PM
DVG's Avatar
DVG
Cool, thanks for the info
One other thing, if I got a clearcoat on the headlights, then decided to bake them to take them apart, would that have any negative effects?
jeffbdye
Jun 1, 2018 03:51 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
