Retrofit Question
Old Aug 28, 2012 | 10:56 PM
CLyons0203's Avatar
Retrofit Question
I plan on doing a projector retrofit to my G35 05 sedan soon. I do not want to do a quad setup. I want to get the Morimoto Mini D2S 2.0 and place it in the low beam area. I want to keep the fog light area the same, but I want my highbeams to trigger the solenoid for the projector.
How does the fog\high beam combo work? I know its the same bulb, but is it two different harnesses? Dual fillament bulb? Will I have to splice the high beam wire into the solenoid harness from the projector?
Will something like this work?
http://www.theretrofitsource.com/pro...oducts_id=9717
If they use the same harness, wont the solenoids activate when the fogs are turned on?
Old Feb 20, 2013 | 02:51 AM
DUNKMAN23's Avatar
Did you get this working? if so how. and are the fogs still working?
Thanks
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
INVADER_6MT
Sep 1, 2015 10:19 PM
